Insert External Reference to Each Layout
Hello everybody,
I have problem with insertion of external reference to each layouts.
Below is the some part of my code and a sub function EXREFEKLE in which i want to add an external reference to each layout.
In the code i can obtain EBATK amount of layouts but my external reference is exisiting only at the first layout.
Best regards
Call EXREFEKLE(ka1K, olc2K, EBATK)
Public Sub EXREFEKLE(ka1K, olc2K, EBATK)
ThisDrawing.ActiveSpace = acPaperSpace
Dim xrefInsertedK As AcadExternalReference
Dim LayoutsK As AcadLayouts
Dim bnoK(0 To 2) As Double
Dim STRPATH1K As String
Dim STRPATH2K As String
Dim STRNAME1K As String
Dim STRNAME2K As String
bnoK(0) = 0
bnoK(1) = 0
STRPATH1K = "D:\MYFOLDER\" & ka1K
STRNAME1K = "TEST"
With ThisDrawing.Utility
For j = 1 To PaftaSay
ThisDrawing.Layouts.Add EBATK & j
Next j
Set LayoutsK = ThisDrawing.Layouts
LayoutsK("Layout1").Delete    ' ok
LayoutsK("Layout2").Delete   ' ok
End With
Set xrefInsertedK = ThisDrawing.PaperSpace.AttachExternalReference(STRPATH1K, STRNAME1K, bnoK, olc2K, olc2K, olc2K, 0, False)
End Sub
norman.yuan
You only insert the Xref once (into the currently active layout), how could expect the Xref to be in all newly created layouts?
ThisDrawing.PaperSpace.AttachExternalReference() only attach a file as Xref to active layout (PaperSpace). Since your code create multiple layouts, you need to make sure to set each new layout as active Layout and attach Xref. Something like:
Option Explicit
Public Sub InserXref()
    Dim lay As AcadLayout
    Dim i As Integer
    Dim xrefFile As String
    Dim xref As AcadExternalReference
    Dim pt(0 To 2) As Double
    xrefFile = "E:\Temp\TestXref.dwg"
    pt(0) = 0#: pt(1) = 0#: pt(2) = 0#
    For i = 1 To 3
        Set lay = ThisDrawing.Layouts.Add("TestLayout" & i)
        ThisDrawing.ActiveLayout = lay
        Set xref = ThisDrawing.PaperSpace.AttachExternalReference( _
            xrefFile, "TestXref", pt, 1#, 1#, 1#, 0#, False)
        xref.Update
    Next
End Sub
HTH
Norman Yuan
Drive CAD With Code
Thank you Norman,
This is what i am looking for.
Regards
