To catch all layer that have a Center lintype
ace_guru
ace_guru
G'day Folks,
I'm trying to write a rountine which helps cleanup externally supplied drawings/block so they can suit our internal system. Currently I'm stuck on being able to select all layers which have a "Center" linetype. I can catch everything where the layers have linetype = "Center". But I can't catch the layers where the linetype = "ByLayer". Hope that makes some sort of sense.
Below is part of the code which tries to do the above...
Sub ChangeAllToLyer()
    Dim ssAll As AcadSelectionSet, mEntity As AcadEntity
    Dim Cnt As Integer
    Dim lTyp As String
    Set ssAll = ThisDrawing.SelectionSets.Add("AllEntities")
    'ThisDrawing.SelectionSets("allentites").Delete
    ssAll.Select acSelectionSetAll
    'Cnt = ssAll.Cnt
    'Debug.Print Cnt
    For Each mEntity In ssAll
        lTyp = mEntity.Linetype
        'Debug.Print lTyp
        'If mEntity.Linetype = "CENTER" Then
        If UCase(lTyp) = UCase("Center") Then
            mEntity.Layer = "4cl"
            mEntity.Color = acByLayer
    Next
    ssAll.Clear
    ssAll.Delete
    Set ssAll = Nothing
End Sub
 Also attached is a sample drawing that I've moocked up so I can see what gets updated. In theory, every layer which has a center type linetype should change to 4cl & cyan.
norman.yuan
It seems that your post's title should be "To catch all entities that have "Center" linetype".
Anyways, "ByLayer" means that propery (LineType, Color,...) of an Entity is determined by the layer it resides. Therefore, you simply trace back to the layer to get the concrete value of the property. In your case, you do:
Dim isCenter As Boolean
Dim layer As AcadLayer
  lType=UCase(mEntity.LineType)
  isCenter=False
  If lType="CENTER" Then
    IsCenter=True
  ElseIf lType="BYLAYER" Then
    set layer=ThisDrawing.Layers(mEntity.Layer)
    If UCase(layer.LineType)="CENTER" Then
      IsCenter=True
  If IsCenter Then
    ''Do whatever you need to here
Next
Norman Yuan
Drive CAD With Code
