Explode 3D solid
Explode 3D solid
Explode 3D solid
I need to convert in VBA a 3D solid object in polylines.
My first idea was to use the "explode" command but this command is not implemented for an object AcDb3dSolid.
Does anyone have an idea to find a way to get around.
Thanks a lot
you can use "SectionSolid" method to obtain a region, and then explode it
jeremye86
thanks for this, instead of exploding, i was able to use getboundingbox  to get the values i needed.
 Set sectionObj = solidObjextrus_1.SectionSolid(pnt7, pnt8, sectionPt1)
sectionObj.GetBoundingBox minExt, maxExt
sectioncoor(6) = maxExt(2)
