I want to export blockcell's image in table object
Message 1 of 10
I Want to export blockcell's image in table object
|  BlockCell  |  TextCell  |
Here is a table, and I click table then BLOCK_CELL is export with imageFile and TEXT_CELL is umm just print debug
I'm trying to AcadTable and TEXT_CELL is use AcadTable.GetCellValue(row, column) success
But BLOCK_CELL how can I export imageFile
I'm trying to Export method. Export method's last argument is SelectionSet
Just Block is possible to AcadBlockreference to Select and export, but the block cells in the table is possible to Select and Export please help me
Replies (9)
Message 2 of 10
norman.yuan
While in my reply to your previous post I said "no", I meant it is not directly. But now that you mentioned to use AcadDocument.Export() method, then I think you can try this in indirect way, with following steps:
1. Find the block definition of the block reference used in a table cell (as Ed_Jobe's reply showed);
2. Find a spot somewhere in the ModelSpace/PaperSpace, where it is clean, and insert a block reference of the block, with proper scale;
3. Zoom to the inserted block reference properly;
4. Add the block reference to a SelectionSet
5. Call the AcadDocument.Export() method to save it as *.wmf, or *.bmp;
6. Erase the block reference
You can repeat the steps for each of the block reference cell in the table.
Norman Yuan
Drive CAD With Code
Message 3 of 10
This is the current implementation.
If the type is block cell while cycling through the table, insertBlock with the block ID and zoom appropriately, and then export.
But this block have property.
So In AutoCad it's same name block but look different but export image is all the same.
Message 4 of 10
norman.yuan
Are you say that the block references in the tables are dynamic block references from the same block definition, but the dynamic property or properties being set to different values (thus the block references look differently)?
If so, for each table cell, you not only find out its block definition, but also its property value(s). Then when inserting the temporary block reference for exporting image, you can set the property value(s) accordingly before doing the export.
Norman Yuan
Drive CAD With Code
Message 5 of 10
Yes AcadTable has GetBlockAttributeValue(row, col, attdefid) method.
But i can't get attribute definition id. So I can't get that dynamic blockcell's attribute value
Message 6 of 10
norman.yuan
Well, I don't entirely understand your situation and what exactly you need. But using AcadDocument.Export() to generate entity/block reference image is doable as I suggested. I happened to have a bit time to play it a bit and following code came out working:
Option Explicit
Public Sub GetBlocksInTable()
    Dim ent As AcadEntity
    Dim pt As Variant
    On Error Resume Next
    ThisDrawing.Utility.GetEntity ent, pt, vbCr & "Select table entity:"
    If ent Is Nothing Then Exit Sub
    Dim tbl As AcadTable
    If TypeOf ent Is AcadTable Then
        Set tbl = ent
        ProcessBlocksInTable tbl
    End If
End Sub
Private Sub ProcessBlocksInTable(table As AcadTable)
    Dim i As Integer
    Dim j As Integer
    Dim cellType As AcCellType
    For i = 1 To table.Rows - 1
        For j = 0 To table.Columns - 1
            cellType = table.GetCellType(i, j)
            If cellType = acBlockCell Then
                WorkOnCell table, i, j
            End If
        Next
    Next
End Sub
Private Sub WorkOnCell(table As AcadTable, row As Integer, column As Integer)
    Dim blockId As LongPtr
    Dim blkNames() As String
    Dim i As Integer
    blockId = table.GetBlockTableRecordId(row, column)
    Dim blk As AcadBlock
    For Each blk In ThisDrawing.Blocks
        If blk.ObjectID = blockId Then
            ''MsgBox "Block name: " & blk.Name
            ReDim Preserve blkNames(i)
            blkNames(i) = blk.Name
            i = i + 1
        End If
    Next
    If i = 0 Then
        MsgBox "No block found in table!"
        Exit Sub
    End If
    '' Save current view - code ommitted
    '' Exporting block imagaes
    ExportBlockImages blkNames
    '' Restore saved view - code omitted
End Sub
Private Sub ExportBlockImages(blkNames As Variant)
    Dim i As Integer
    Dim blkName As String
    Dim exportPath As String
    exportPath = "C:\Temp\"
    For i = 0 To UBound(blkNames)
        blkName = blkNames(i)
        ExportBlockImage blkName, exportPath
    Next
End Sub
Private Sub ExportBlockImage(blkName As String, exportPath As String)
    '' Insert block at 0,0
    Dim blkRef As AcadBlockReference
    Dim insPoint(0 To 2) As Double
    insPoint(0) = 0#: insPoint(1) = 0#: insPoint(2) = 0#
    Set blkRef = ThisDrawing.ModelSpace.InsertBlock(insPoint, blkName, 1#, 1#, 1#, 0#)
    blkRef.Update
    ZoomToBlock blkRef
    '' export
    DoImageExport blkRef, exportPath & blkName
    blkRef.Delete
End Sub
Private Sub ZoomToBlock(blk As AcadBlockReference)
    Dim minPt As Variant
    Dim maxPt As Variant
    blk.GetBoundingBox minPt, maxPt
    Dim minP(0 To 2) As Double
    Dim maxP(0 To 2) As Double
    Dim deltaH As Double
    Dim deltaW As Double
    deltaW = (maxPt(0) - minPt(0)) * 0.1
    deltaH = (maxPt(1) - minPt(1)) * 0.1
    minP(0) = minPt(0) - deltaW: minP(1) = minPt(1) - deltaH: minP(2) = minPt(2)
    maxP(0) = maxPt(0) + deltaW: maxP(1) = maxPt(1) + deltaH: maxP(2) = maxPt(2)
    ZoomWindow minP, maxP
    ThisDrawing.Utility.GetString 0, vbCr & "Exporting block """ & blk.Name & """. Press Enter to continue..."
End Sub
Private Sub DoImageExport(blk As AcadBlockReference, fileName As String)
    Dim ss As AcadSelectionSet
    Set ss = ThisDrawing.SelectionSets.Add("mySet")
    If Err.Number <> 0 Then
        Err.Clear
        Set ss = ThisDrawing.SelectionSets("MySet")
    End If
    Dim ents() As AcadEntity
    ReDim ents(0)
    Set ents(0) = blk
    ss.AddItems ents
    ThisDrawing.Export fileName, "bmp", ss
    ss.Delete
End Sub
This video clip shows the code in action:
Of course you may need to resize AutoCAD's window, its drawing background... to make the exported image in desired condition (size/back color...). Hope this helps a bit.
Again, I do not know what your situation is, cant say more. You might want to post/attach your drawing to make things clearer.
Norman Yuan
Drive CAD With Code
Message 7 of 10
Thank you. It helps me a lot
Message 8 of 10
aridzv
@norman.yuan
your code works amaizing!!
I have one small issue:
I use 3D blocks and use "Modeling" view style.
when runnuig your code the .bmp image show as 2dwireframe (see attached .bmp).
is there a way to make the .bmp show it as "Modeling" view style?
see attached .dwg file with table that contain blocks in it and a .bmp file show the resault of your code.
thanks,
aridzv.
Message 9 of 10
Ed__Jobe
When you model in modelspace, the view is usually 2Dwireframe. Just change it to the style you want, export the bmp, then change it back to 2Dwireframe. you can use the VSCURRENT command.
Ed
How to post your code.
Message 10 of 10
aridzv
Hi  ed.
I used the above code in model space when the model space visual style is alredy set to "Modeling"....
the solution I found was to use "pngout" instad of
and you solved my problem with pngout here:
https://forums.autodesk.com/t5/vba/give-file-name-to-pngout/m-p/13427822#M108932
Thanks!!
