How to Use filename in place of "ThisDrawing"
I am looking to replace the "thisdrawing" with the actual file name, any insight you can provide would be appreciated. I am looking to move this code out of the drawings so the "thisdrawing" won't be applicable
Public Sub BreakAllLines()
    Dim ent As AcadEntity
    Dim line As AcadLine
    Dim broken As Boolean
    Dim go As Boolean
    Do
        go = False
        For Each ent In ThisDrawing.ModelSpace
            If TypeOf ent Is AcadLine Then
                Set line = ent
                If BreakLine(line) Then
                    go = True
                    Exit For
                End If
            End If
        Next
    Loop Until Not go
End Sub
Ed__Jobe
No matter what module you put the code in, ThisDrawing will always be set to the active drawing.
Ed
How to post your code.
Thanks Ed,
but if I want to replace the "ThisDrawing." with the file name so I can run the code from Excel, how do I do that?
norman.yuan
ThisDrawing in AutoCAD VBA is a built-in reference to the ActiveDocument (AcadDocument) of the AcadApplication. You cannot replace it with a file name, which is a String.
When you automate AutoCAD from external application (Excel VBA, in your case), your code is responsible to obtain the target AcadDocument object to work with. Knowing a file name, you obvously need to open it in AutoCAD, upon opening, you get an AcadDocument object, and then work with it. Something like:
Dim fileName as String
fileName="C:\Temp\MyDrawing.Dwg"
Dim cadApp As AcadApplication
Dim dwg As AcadDocument
''Here goes the code to get an existing Acad application instance, or create a new one...
'' Then you open the drawing in AutoCAD
'' (or you can dertermine if the fiel has already open in existing Acad session, which I believe we have already discussed it previously)
Set dwg=cadApp.Documents.Open(fileName....)
'' Now you have the reference to the target AcadDocument, do whatever as you do with "ThisDrawing" in AutoCAD VBA: simply replace ThisDrawing with "dwg":
For Each ent in dwg.ModelSpace
Next
Norman Yuan
Drive CAD With Code
