How to use comdlg32.ocx in AutoCAD 2016
truewaytw
Message 1 of 8
truewaytw
hi,
i reference the comdlg32.ocx for c:\windows\syswow64 , but cannot put it into my userform , how can fix the trouble ?
bruce
Replies (7)
Message 2 of 8
Alfred.NESWADBA
32bit OCX can only be used by 32bit applications.
If your operating system is based on 64bit then your AutoCAD and so VBA is running on 64bit.
You'll have to replace that controls by other ones supported on 64bit .
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 8
truewaytw
Hi alfred,
have any element do you know can be run in 64bits os like comdlg32.ocx ?
bruce
Message 4 of 8
Alfred.NESWADBA
Sorry, didn't need any, but there are some valuable suggestions in this search I guess, >>>click<<<
- alfred -
Alfred NESWADBA
Message 5 of 8
truewaytw
Hi Alfred,
       thanks.
bruce
Message 6 of 8
Hi @Alfred.NESWADBA
you wrote "32bit OCX can only be used by 32bit applications."
but while trying to answer to >>this post<<  I happend to meet >>This SO post<< which seem to say the opposite!
actually I succeeded at running "comdlg32.dll" in my full 64 environment (W7 SP1 64 bit & Autocad 2014)
am I correctly addressing the issue?
Message 7 of 8
norman.yuan
comdlg32.ocx and comdlg32.dll are not the same thing: the latter is Windows API. As the link you rfrerred to, it can be used in 64-bit process with proper P/Invok; while the former is the ActiveX UI wrapper to comdlg.dll, which is 32-bit, thus cannot be used in 64-bit VBA (since Acad2014).
Norman Yuan
Drive CAD With Code
Message 8 of 8
I made a mess
thank you for catching that
