Are there any informations (ebook, help etc ) about programming in c# ActiveX ?
Message 1 of 1
(the same idea like vba but code written in c#) ?
This is not a .NET API programming.
I read about this in ActiveX and VBA Developer's Guide in Autocad Help.
You can add references:
 - The AutoCAD 2009 type library, acax17enu.tlb
 - The AutoCAD/ObjectDBX Common 17.0 type library, axdb17enu.tlb
These references will make available the following primary interop assemblies:   - Autodesk.AutoCAD.Interop.dll
  - Autodesk.AutoCAD.Interop.Common.dll
Thank you in advance
Replies (0)
