How to respond to an add-in's window (pop-up) in AutoCAD programmatically ?
Kh.mbkh
Kh.mbkh
When starting an AutoCAD add-in (with the command "StartPlong"), a pop-up window appears:
Capture.PNGI wonder if it's possible to answer this window (pop-up) by checking the CheckBox1, clicking the button 2, and 3 ... programmatically.
By searching on the Net, I found some solutions (Use Spy++ to get hundle of buttons ... ) but can't come up with a solution.
Thanks !
seabrahenrique
Well,
If you have access to the code of this plugin, is pretty easy to do this on the "Activated" event form:
Checkbox1.Value = true: ListBox1.Selected(1) = True: Call ClickButtonEvent
But without access the code, in my knowledge, is not possible to do this with another add in VBA.
Maybe your solution could be something like a click macro recorder...
I hope can help!
Kh.mbkh
It is a foreign Add-in (we don't have the code, and we don't know whit which language ti's done).
Ed__Jobe
Ask the add-in vendor if there is a command line version that would allow you to specify the arguments.
Ed
How to post your code.
Kh.mbkh
looking for a solution in programming, which will certainly exist...
Kh.mbkh
For anyone who may be interested, I fixed my issue using PywinAuto (A Python library) to do Scraping.
