How to remove a sheet from SSM?
Joel_S_Hills
Joel_S_Hills
I am looking for a way to remove a sheet from a .dst file aka Sheet Set Manager using VB
I found a something similar with lisp, (dictremove (namedobjdict) "AcSheetSetData")
but it dosen't remove the file from the .dst file
Any tips?
norman.yuan
In VBA, you can use Sheet Set Manager Objects (SSO) to manipulate sheet set. You add reference to AcSmComponents2x.tlb to your VBA project and off you go. Searching this forum or the Internet would bring you a few links with code sample. For example, this link:
https://blog.jtbworld.com/2006/04/sheet-set-manager-code-snippets.html
Norman Yuan
Drive CAD With Code
Joel_S_Hills
Joel_S_Hills
Good stuff in there but nothing that removes a sheet from the .DST file
