How to insert drawing file contents side by side?
Mesut_Akcan
Mesut_Akcan
There are many dwg drawing files. The contents of these drawing files are not the same width and height. How to insert multiple drawing file contents side by side with a certain space in between?
Mesut Akcan - Emekli Teknik Öğretmen
Blog Sayfam -- Youtube Kanalım -- LinkedIn
Ed__Jobe
If I understand you correctly, I recommend that you don't put multiple drawings into model space. Leave them separate and use a sheet set (PUBLISH command) to plot them. If they have common areas, then put the model into an xref. This is the way AutoCAD is designed to work. Put your title blocks into a paperspace layout. If you do it your way, you will make a lot of extra work for yourself because you won't be able to use the built-in tools.
Ed
How to post your code.
maratovich
To merge drawings use this - AutoImportCAD
If you need to print from one drawing or from many automatically, then perhaps this will help you - Revers
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
