How to grouping lines to a block?
sprtolansgz
Observer Observer
sprtolansgz
Observer
Observer
Iwant to create a square with autocad and grouping them to block. OLANSGZ
Call CreateLine(p1, p2) 'creating top line
Call CreateLine(p2, p3) 'creating right line
Call CreateLine(p3, p4) 'creating bottom line
Call CreateLine(p4, p1) 'creating left line
Function CreateLine(firstPoint, secondPoint)
    Dim StartPoint(0 To 2) As Double
    Dim EndPoint(0 To 2) As Double
    StartPoint(0) = firstPoint(0)
    StartPoint(1) = firstPoint(1)
    StartPoint(2) = 0
    EndPoint(0) = secondPoint(0)
    EndPoint(1) = secondPoint(1)
    EndPoint(2) = 0
    With ThisDrawing.ModelSpace
    .AddLine StartPoint, EndPoint
    .Item(.Count - 1).Update
    End With
End Function
now I want grouping this square to a block with a custom name with VBA and AutoCAD. How can I do?
Ed__Jobe
Model Space is just a block. Just add a block using
Dim myBlock as AcadBlock
Set myBlock = ThisDrawing.Blocks.Add(insPt, "myblock")
to create a block with the name you want. Then replace
with
myBlock
Sub AddMyBlock ()
  Dim insPt(0 to 2) As Double 'default to 0,0,0
  With myBlock
    Dim l As AcadLine
    dim cnt As Integer
    For cnt = 0 To 3
      Set l = .AddLine(pt1, pt2) 'pt's need to be defined somewhere.
      l.Layer = "0"
    Next cnt
    .Layer = "0"
  End With
End Sub
Ed
How to post your code.
