How to grouping lines to a block?
m09366023695
m09366023695
I want to create a square with autocad and grouping them to a block.
Call CreateLine(p1, p2) 'creating top line
Call CreateLine(p2, p3) 'creating right line
Call CreateLine(p3, p4) 'creating bottom line
Call CreateLine(p4, p1) 'creating left line
and my function:
Function CreateLine(firstPoint, secondPoint)
Dim StartPoint(0 To 2) As Double
Dim EndPoint(0 To 2) As Double
StartPoint(0) = firstPoint(0)
StartPoint(1) = firstPoint(1)
StartPoint(2) = 0
EndPoint(0) = secondPoint(0)
EndPoint(1) = secondPoint(1)
EndPoint(2) = 0
With ThisDrawing.ModelSpace
.AddLine StartPoint, EndPoint
.Item(.Count - 1).Update
End With
End Function
now I want grouping this square to a block with a custom name with `VBA` and AutoCAD.
How can I do?
seabrahenrique
Well,
Have u consider to use the creation of lines direct on the block? Like that:
Sub CreateSquareAndFormBlock()
    '0 Declarations and variables
    Dim blockName As String, insPt(0 To 2) As Double, Line As AcadLine, MyBlock As AcadBlock
    Dim p1(0 To 2) As Double, p2(0 To 2) As Double, p3(0 To 2) As Double, p4(0 To 2) As Double
    blockName = "NewBlock"
    'Form your square
    p2(0) = 10: p2(0) = 10:  p3(0) = 10: p3(1) = 10: p4(1) = 10
    'Create a new block
    Set MyBlock = ThisDrawing.Blocks.Add(insPt, blockName)
    'ADD LINES DIRECT ON YOUR BLOCK
    MyBlock.AddLine p1, p2
    MyBlock.AddLine p2, p3
    MyBlock.AddLine p3, p4
    MyBlock.AddLine p4, p1
    'Add the blockreference in model space
    ThisDrawing.ModelSpace.InsertBlock insPt, blockName, 1, 1, 1, 0
End Sub
I guess this is a more simples way to do your propose.
But if you really want to do a lines by a function, so, consider to transform your function in a Line typed function like that:
Function CreateLine(firstPoint, secondPoint) As AcadLine 'Diference one
StartPoint(2) = 0
EndPoint(2) = 0
Set CreateLine = .AddLine(StartPoint, EndPoint) 'Diference two
End With
End Function
And then you also can Add a created line by your function in a block, got it?
(But i guess the first way is more simple and better)
Hope can help u!
