how to clear (*pop-error-mode*) using
MakCADD
Message 1 of 11
MakCADD
How can i clear this error message using VBA
which occurs while escaping from the express commands
(*pop-error-mode*) underflow.
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
every time I have to restart the autocad to use the express commands again
Replies (10)
Message 2 of 11
Ed__Jobe
Are we to assume that you are using VBA SendCommand to call these lisp routines? Which Express commands are you having trouble with?
Ed
How to post your code.
Message 3 of 11
MakCADD
this is the error message from autocad, when I break the execution of an autocad express command
then you will get the same error message while using the express commands untill you restart autocad
I did it before with the help of someone
using lisp,  I forgot it,  I am not familiar with lisp
so i  thought it could be better to to use with sendcommand
instead of restarting autocad everytime
Message 4 of 11
Ed__Jobe
You didn't say which ET commands you are having a problem with.
Ed
Message 5 of 11
MakCADD
GATTE command  to edit attributes
Message 6 of 11
Ed__Jobe
If I just run the command, I can't replicate your error. What steps are you using to get the error?
Ed
Message 7 of 11
MakCADD
i cancelled the command using esc key without selecting any objects
then i revoke the command again ,  it shows the error
it shows the same error for other express commands
Message 8 of 11
Ed__Jobe
I typed "GATTE" at the command line and hit ESC, but I can't replicate your error. Are you using this command in VBA? Is that why you are posting in the VBA forum and not the lisp forum? I've been using VBA and C# for a number of years, so my lisp is a little rusty.
Ed
Message 9 of 11
MakCADD
@Ed__Jobe
hello jobe,
thank you for your response.
yes, it is to be captured in lisp, I am not that much expert on lisp, so tried to find a solution through vba.
before i solved by entering the lisp code in command prompt using vba. (...utility.prompt) ,  i lost that code.
now  i could not revoke that error,  i dont know what happend.
next time ill copy all the command history  for your reference
again thanks for your time
Message 10 of 11
Ed__Jobe
Then I would post this question in the LISP forum. I think some others have modified the ET commands. I think I did too, but can't remember what I did. I'm using 2021 now and it seems to be fixed.
Ed
Message 11 of 11
MakCADD
Here is the command history for an express command for autonumbering
I hit the escape key,  instead of selecting the object.
The result is this.
I used this command successfully right now.
now I have to restart autocad to eliminate this error
Command:
TCOUNT
Select objects: Specify opposite corner: 10 found
Select objects:
Sort selected objects by [X/Y/Select-order] <Y>:
Specify starting number and increment (Start,increment) <1,10>: 0,10
Placement of numbers in text [Overwrite/Prefix/Suffix/Find&replace..] < Overwrite>: *Cancel*     😀👾👾
Command:
Command: "INTERNAL error in FAIL\nmessage lost, reset to top"
Command: *Cancel*
Command: *Cancel*
Command:
TCOUNT
Command:
TCOUNT
Command:
