How print the contents of a list box?
I've written a bit of code that goes off and does a search and then shows the results in a list box, but i'd also like to be able to print it out. Using the common dialog box control from comdlg32.ocx, i've ended up with the following, which i based on a VB6 program that used a rich text box:
Private Sub cmd_print_Click()
On Error Resume Next
With CommonDialog1
.CancelError = True
.DialogTitle = "Print Seach Results"
.PrinterDefault = True
.flags = cdlPDHidePrintToFile Or cdlPDNoPageNums Or cdlPDReturnDC
.flags = .flags Or cdlPDNoSelection
.ShowPrinter
If Err = 0 Then
' Print the entire contents of the text box
printer.Print lst_result.Text
End If
End With
End Sub
I end up with the print dialog showing OK, but nothing comes out. The rich text box program also had same format for printing, only it was printer.print richtextbox.text.
What do i need to do to get the contents printing out?
TIA.
Maybe printer.enddoc
You might need to loop through the list box
ie
for i = 0 to me.lstBx.listcount-1
 printer.print me.lstBx.list(i)
next i
printer.enddoc
HTH
Chris
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I've
Private Sub
cmd_print_Click()
        On Error
Resume Next
    With CommonDialog1
        .CancelError = True
Seach Results"
        .flags =
        .flags = .flags Or
cdlPDNoSelection
        .ShowPrinter
        If Err = 0 Then
                printer.Print
lst_result.Text
        End If
    End With
End Sub
richtextbox.text.
TIA.
Found out why it won't work. The printer object doesn't exist in VBA, only in VB, so i have to use word or some other program instead to print through.
