How Can I Select All Block Attributes Using VBA Coding
Amremad
Message 1 of 9
Amremad
How Can I Select All Blocks Attributes Using VBA Coding
all blocks with any name with any layer with any property
thx 4 all
Replies (8)
Message 2 of 9
Alfred.NESWADBA
look to getAttributes-function of the BlockReference in the help, there you see how to access attributes.
This sample is in the help:
Sub Example_GetAttributes()
    ' This example creates a block. It then adds attributes to that
    ' block. The block is then inserted into the drawing to create
    ' a block reference.
    ' Create the block
    Dim blockObj As AcadBlock
    Dim insertionPnt(0 To 2) As Double
    insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
    Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "TESTBLOCK")
    ' Define the attribute definition
    Dim attributeObj As AcadAttribute
    Dim height As Double
    Dim mode As Long
    Dim prompt As String
    Dim insertionPoint(0 To 2) As Double
    Dim tag As String
    Dim value As String
    height = 1#
    mode = acAttributeModeVerify
    prompt = "Attribute Prompt"
    insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0
    tag = "Attribute Tag"
    value = "Attribute Value"
    ' Create the attribute definition object in model space
    Set attributeObj = blockObj.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
    ' Insert the block
    Dim blockRefObj As AcadBlockReference
    insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
    Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "TESTBLOCK", 1#, 1#, 1#, 0)
    ZoomAll
    ' Get the attributes for the block reference
    Dim varAttributes As Variant
    varAttributes = blockRefObj.GetAttributes
    ' Move the attribute tags and values into a string to be displayed in a Msgbox
    Dim strAttributes As String
    Dim I As Integer
    For I = LBound(varAttributes) To UBound(varAttributes)
        strAttributes = strAttributes & "  Tag: " & varAttributes(I).TagString & _
                        "   Value: " & varAttributes(I).textString & "    "
    Next
    MsgBox "The attributes for blockReference " & blockRefObj.name & " are: " & strAttributes, , "GetAttributes Example"
    ' Change the value of the attribute
    ' Note: There is no SetAttributes. Once you have the variant array, you have the objects.
    ' Changing them changes the objects in the drawing.
    varAttributes(0).textString = "NEW VALUE!"
    Dim newvarAttributes As Variant
    newvarAttributes = blockRefObj.GetAttributes
    ' Again, display the tags and values
    strAttributes = ""
    Next
End Sub
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 9
Amremad
thank you Mr. alfred.neswadba
but you understand me i need just use the selection method to select all block in drawing but i don't know how can i change the vlaue of FilterType and FilterData
this function "Sel.SelectOnScreen FilterType, FilterData"
Message 4 of 9
Alfred.NESWADBA
you can't select AttributeReferences directly with any Select-function as AttributeReferences are always subobjects of BlockReferences.
So you have to select all BlockReferences, then scan through them and use GetAttributes to get access to the AttrbuteReferences.
- alfred -
Alfred NESWADBA
Message 5 of 9
Amremad
yes it's ok
and that's i need ,
can you help me how can control with filteration variables to can select all blocks in dwg? using selection method
understand me??
Message 6 of 9
Alfred.NESWADBA
have you looked to the VBA-help for selectionset? The help shows how to select Circles, change it to select "INSERT"-objects ("INSERT"=DXF-Code for BlockReferences)
This is from the help:
Sub Example_Select()
    ' This example adds members to a selection set, first by crossing and
    ' then by filtering for circles.
    ' Create the selection set
    Dim ssetObj As AcadSelectionSet
    Set ssetObj = ThisDrawing.SelectionSets.Add("SSET")
    ' Add all object to the selection set that lie within a crossing of (28,17,0) and
    ' (-3.3, -3.6,0)
    Dim mode As Integer
    Dim corner1(0 To 2) As Double
    Dim corner2(0 To 2) As Double
    mode = acSelectionSetCrossing
    corner1(0) = 28: corner1(1) = 17: corner1(2) = 0
    corner2(0) = -3.3: corner2(1) = -3.6: corner2(2) = 0
    ssetObj.Select mode, corner1, corner2
    ' Add all the Circles to the selection set that lie within the crossing of (28,17,0) and
    ' (-3.3, -3.6,0) by filtering from the current drawing
    Dim gpCode(0) As Integer
    Dim dataValue(0) As Variant
    gpCode(0) = 0
    dataValue(0) = "Circle"
    Dim groupCode As Variant, dataCode As Variant
    groupCode = gpCode
    dataCode = dataValue
    ssetObj.Select mode, corner1, corner2, groupCode, dataCode
End Sub
- alfred -
Alfred NESWADBA
Message 7 of 9
Amremad
so what is the word can i replace the circle to can select block ??
i  tried AcadBlockReference but it's not working
Message 8 of 9
Amremad
FilterType(0) =0
FilterData(0) = "INSERT"
this is the correct solution that i need
but i don't know what 's mean insert word?
thanks mr for your help
Message 9 of 9
Hi.
I need little help. I want to know how to select all attributes like TAG and VALUE from CAD document.
If I use
Dim elem As Object
For Each elem In ThisDrawing.ActiveSelectionSet, this retun me just one of set TAGs and VALUE, but in document I have this more.
Sorry for my english. An thank you for help.
