loft and the ugly sendcommand
hello everyone,
i know you should never use sendcommand but its  last chance saloon time.
i already have created 2 circles:
Set objCircle1 = ThisDrawing.ModelSpace.AddCircle(objLine.startpoint, dblDia1 / 2)
Set objCircle2 = ThisDrawing.ModelSpace.AddCircle(objLine.endpoint, dblDia / 2)
now i would like to loft between them, they are not concentric else i would use AddRevolvedSolid.
how do i structure the loft command? i guess i need to send the id or handle of these circles
so i tried
strHandle1 = objCircle1.Handle
strHandle2 = objCircle2.Handle
this doesnt work:
ThisDrawing.SendCommand "loft" & vbCr &  strHandle1 &  strHandle2 & vbCr & vbCr
how do i correctly send objects to the command line?
any useful input would be wonderful! thanks
Alfred.NESWADBA
try this with your handles instead of mine from my small sample
   Dim tHandleStr1 As String: tHandleStr1 = "25E"
   Dim tHandleStr2 As String: tHandleStr2 = "25D"
   Call ThisDrawing.SendCommand("_LOFT" & vbCr & "(handent """ & tHandleStr1 & """)" & vbCr & "(handent """ & tHandleStr2 & """)" & vbCr & vbCr & vbCr)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
thanks very much, that works fine. the devil is in the details!
