Hatch area
Hatch area
Hatch area
Hi;
How do I calculate the height, width and area of a hatch?
Is it possible at all?
David
Strängbetong, Sweden
I have tried something similar with no luck. If you find a way let me know.
"David" wrote in message
news:8732D4B26A0C5EAA6DEC572E0F1559C5@in.WebX.maYIadrTaRb...
> Hi;
> David
There's almost nothing impossible you know.
Sub CalcullateHatchThings()
Dim Ent As AcadEntity
Dim Pt As Variant
Dim PtMin, PtMax
ThisDrawing.Utility.GetEntity Ent, Pt, "Sélect one hatch"
Ent.GetBoundingBox PtMin, PtMax
'Area
MsgBox Ent.Area & " Units Square"
'Height
MsgBox PtMax(1) - PtMin(1) & " Units for Height"
'Width
MsgBox PtMax(0) - PtMin(0) & " Units for Width"
End Sub
LOL... lets discard that last answer, since it is only valid if the hatch is a rectangle.
Here is a posibility (that I did not try, but it sould work):
Hatch boundaries work pretty mutch the same way that a region boundary work. So if you could extract the boundaries of a hatch, (GetLoopAt), then use the given entities to create a Region, you will then be able to use the Area property te get the area of the original hatch.
Problem is, this only works on associative hatches..... but it should work.
