How do I get area information into my database?
Message 1 of 8
I am creating a link between a drawing and database. Is it possible feed area data from a polyline automatically in to the database when linking the polyline to the data base.
Replies (7)
Message 2 of 8
yes as long as you have the handle of the polyline
you can link a variable, polMyPolyline, to the object. example
Dim polMyPolyline As AcadPolyLine, str As
String
set polMyPolyLine =
thisdrawing.HandleToObbject('Hanlde here')
'use a string to store the information it may be to
large for an integer and takes less memory than a long
str = polMyPolyLine.Area
I
Message 3 of 8
Thanks for your response.
Could you go into to more detail of how to do this, I haven't used VBA before?
Message 4 of 8
First link your DBase I assume its Access so set
your references to use ADO, Microsoft ADO...". Dim a string Variable to link
your DBase with.
'Place this UNDER Option Explicit at the beginning
of your code.
Public Const strYourString As String =
"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=c:\YourDBase.mdb"
"Private Function" OR "Public Sub" 'you choose'
modGetArea()
'this is an example of your code for the DBase
access
Dim polMyPolyline As AcadPolyLine, strMyString As
String
Dim strDBaseHandle As String, cnnConnection As New
ADODB.Connection
Dim rstMyRecordset As New
ADODB.Recordset
Dim strHandle As String
cnnConnection.Open strYourString
size=2>     rstMyRecordset.CursorLocation =
adUseClient
     rstMyRecordset.CursorType =
adOpenKeyset
     rstMyRecordset.LockType =
adLockOptimistic
'tblYour is the name of the table containing the
Handle for the Polyline and the Area of the
Polyline
     rstMyRecordset.Open "'tblYour ", cnn,
adOpenDynamic
Do While Not rstMyRecordset.EOF
    strHandle = rstMyRecordset!Handle
'Handle is the name of the field in the Table where the objects handle
is stored.
    set polMyPolyLine =
thisdrawing.HandleToObbject(strHandle)
    strMyString =
polMyPolyLine.Area
    rstMyRecordset!Area = strMyString
   'If you are using the Field AREA as a number in your
database then you need to use this
    'rstMyRecordset!Area = Val(strMyString) OR
USE rstMyRecordset!Area = CInt(strMyString)
    ' I recommend the first one.
Loop
End "Function OR Sub"
This will help you on your way.
for your response.
before?
Message 5 of 8
Thank you
I'll have a go with this.
Message 6 of 8
I'm sorry, I can't get this to work. Do I have to do this in Access or AutoCAD?
Message 7 of 8
within ACAD. make sure that the string for your
public const is read as a single line. other than that I can't see where there
should be any problems. what errors are you getting.
I'm
AutoCAD?
Message 8 of 8
I'm not getting any errors, I guess I just don't know how to go about this.
