Give file name to pngout
aridzv
aridzv
Hi.
I need to use pngout command and give it a filename alredy stored in a varaible named "filename".
I searched for this issue but found no answer.
I use this line of code to lunch the pngou command:
ThisDrawing.SendCommand ("pngout" & vbCr)
at that point I get the "Save File" window.
How d I send the "filename" varible to the file name field in the save file window and simulate enter?
thanks,
aridzv
Ed__Jobe
Whenever you need to respond to a file dialog programmatically, you can turn the dialog off by setting FILEDIA = 0. Then your code would look like
ThisDrawing.SetVar "fildia" 0
ThisDrawing.SendCommand "pngout " & filename & vbCr
ThisDrawing.SetVar "fildia" 1
Note the space after pngout
Ed
How to post your code.
aridzv
Thanks!!!💪
 EDIT:
the line with the space in the pngout didnt work for me so I use it without the space...
ThisDrawing.SendCommand ("PNGOUT" & vbCr & fileName & vbCr)
