GetObject / CreateObject
I have a VB6 program. At the start of the program I check
to see if a session of AutoCAD is running.
Set myApp = GetObject(, "AutoCAD.Application")
The problem is that although AutoCAD is running, Err
is true and my program opens a new session of AutoCAD
If Err Then
Err.Clear
Set myApp = CreateObject("AutoCAD.Application")
I have AUTOCAD 14 running on Win NT.
Public Sub Main()
On Error Resume Next
If Err Then
Err.Clear
If Err Then
MsgBox Err.Description
Exit Sub
End If
End If
Set myDoc = myApp.ActiveDocument
End Sub
ehm... i thought the answer to this question is that you have to use
AutoCAD.Application.14
Did i win?
wkr, jkw
You ask a silly question, you get a technical answer...
Mal had the next bright idea:
The problem is
If Err Then
>    Err.Clear
Public Sub Main()
If Err Then
>    Err.Clear
    Set
>    If Err Then
        Exit Sub
>    End If
>End If
End Sub
Thanks for your input.
but akkkkkkkkk!!! no winner
On most of our systems just
works
but adding the 14 does not work on any of our systems.
"AutoCAD.Application.14"
stumped ????, I am !!
We also have LDDT and AutoCAD map on these systems.
It is something in that direction. Unless someone else from the newsgroup
can tell you what the correct name is, you have to search in the registry
to find the correct description of AutoCAD.Applictation.Blablablah. If you
find the correct description for the systems with map and lddt (which is
probably the troublemaker), maybe you can code a construction like;
on error resume next
getobject with only application
do something
if that is not working, use application.14
do something
if that isn't working...
(this reply is probably more confusing than the previous... 🙂
wkr, jwk
>works
We also have
I think your code is working. look at the windows task manager and you will that the processus acad.exe is running
If Err Then
Err.Clear
If Err Then
Exit Sub
End If
End If
myApp .windowstate = acmax
myApp.ActiveDocument.windowstate=acmax
