Getting current LDDT project
Does anyone out there, who is using LDDT2i, know how to get the current
project into a textbox? I want to take the current project that is shown at
the top of LDDT and put it into a textbox to record plots. The following
code works in VBA but does not work in VB6. Does anyone have a method that
does work?
Dim proj As String
proj = AeccApplication.ActiveProject.Name
TextBox1.Text = proj
Thanks for any help,
Jason Stevens
Hi Jason,
This works for me in VB6 with references set to AutoCAD2000 and AutoCADLand:
Set appAcad = GetObject(, "AutoCAD.Application.15")
Set ldd = appAcad.GetInterfaceObject("Aecc.Application")
TEXTBOX=ldd.ActiveProject.Name
Bud Miller
www.BudCAD.com
"Jason Stevens" wrote in message
news:735913368D94B86D7A06A5DE954686DD@in.WebX.SaUCah8kaAW...
at
that
> does work?
> Dim proj As String
> Jason Stevens
Sorry,
Use ldd.path for the entire path
Bud
at
that
> does work?
> Dim proj As String
> Jason Stevens
That works great. Thank you very much.
Jason
Bud Miller wrote in message
news:BB85FF4F1D97163590CEF299CF115B59@in.WebX.SaUCah8kaAW...
> Sorry,
> Bud
shown
> at
following
> that
> > does work?
> > Dim proj As String
> > Jason Stevens
This works great, now I am trying to fix it so if the drawing is not
associated with a project it will display a message saying so before it runs
my program. The problem is that when I run the VB program it causes a Fatal
Error when it tries to set ldd because the drawing is not associated with a
project. How would I check to make sure the drawing is associated with a
project without crashing LDDT2i?
Dim appAcad As Object
Dim ldd As Object
'On Error Resume Next
If ldd.ActiveProject.Name = "" Then
MsgBox "Drawing is not associated with a project", vbOKOnly
TextBox1.Text = "No Project"
Exit Sub
Else
TextBox1.Text = ldd.ActiveProject.Name
Jason
> Sorry,
> Bud
shown
> at
following
> that
> > does work?
> > Dim proj As String
> > Jason Stevens
