Font name different from PC to another
joh.richard
joh.richard
I use uUtocad 2018
I created a new style (Barecode) I want to use  the font 3of9
The problem a got is the name in C:\windows\font is not the same on every PC
Here the code
            Set ObjTextStyleBarcode = ThisDrawing.TextStyles.Add("BARCODE")
                ObjTextStyleBarcode.fontFile = "C:\Windows\Fonts\3OF9_4.TTF"
                ObjTextStyleBarcode.Height = "24"
                ObjTextStyleBarcode.ObliqueAngle = 0
                ObjTextStyleBarcode.TextGenerationFlag = 0
                ObjTextStyleBarcode.width = 1
The font name on my PC is 3OF9_4.TTF on another PC the font name is 3OF9_5.TTF.
I try to rename the font, without succes.
How could I get the right name?
almutaz_86
  1. Try to copy 3OF9_4.TTF from your PC
  2. Then past it in the other PC
joh.richard
Thanks @almutaz_86for your advice,
Unfortunately, when I copy the font,  he crushes the existing font and increments the numbre at the end (ex 3OF9_2.TTF to 3OF9_3.TTF)
I also delete the policre and install a new one, with the same result (incrementation )
Looks like it's stored in the PC's memory
A got the font 3OF9_9.TTF on one of my PC
joh.richard
We alway have the problem.... any suggestion
grobnik
Hi @joh.richard here is a link to Autodesk support how to installa a font.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Where-to...
As alternative, as suggested, instead copy and paste on the other PC you can try to install, by right click on c:\windows\font folder and install.
Seems to be a stupid and silly answer but, I hope you have administrator rights on PC's where do you want to install new font.
Regards
