.exe (COM\Active X) as custom menu command
snappyjazz
snappyjazz
I made a .exe in Visual Studio using COM\Active X. It is a program dialog that the user picks a block to insert, the block gets inserted, then gets rotated. I have it working in VS, but now I want to operate it from autocad at the push of a button. So I copy\paste the .exe from the ...vsproj\bin\debug folder to a trusted location. Then I created and added a command to the menu of our cuix(see below). When I clicked the button it failed(see below). I tried googling my goal as well as the forums\help, but I couldn't find my exact situation or the answer is too complicated. Can you please help me in layman's terms. 🙂
Ed__Jobe
You can't run an exe (out-of-process) file inside AutoCAD's process. You need to change your VS project to a dll project (in-process). Then you use the NETLOAD command to load your dll. Create a command in the dll that you can call from the button macro. It seems that you are missing some basic knowledge on programming. I would pick up a book that teaches Object Oriented Programming, OOP.
Ed
How to post your code.
snappyjazz
I do have gaps in my limited programming knowledge. I am self taught after all and the few years I have been doing this has been just looking up specific concepts to accomplish goals. If as you say that learning in-process or out-of-process is basic then now's a good time to learn. However anything I look up on the subject goes to ASP.Net Core which is "a cross-platform, high-performance, open-source framework for building modern, cloud-enabled, internet-connected apps". This sounds like its a lot more complicated than vb.net; also I'm not sure what an internet-connected app has to do with working inside of or outside of autocad. If you think I need to figure out ASP.Net Core to accomplish my goal then I will, but can you understand my reluctance?
Ed__Jobe
No, you don't need to learn asp.net. This search "in-process application vs out-of-process" brought up this article for more info.
If you run TaskManager, you can get an idea about processes. See my screen capture. An EXE creates it's own running process. It can load dll's into it's process, creating another process running within it's own process. AutoCAD has many processes running. However, an exe cannot have another exe running in it's process. Each EXE starts it's own process. They can 'talk' to each other using COM, but your EXE can't run inside acad's EXE.
Ed
snappyjazz
OOOH! That made more sense then reading about in-process for two hours. Thank you!
Ed__Jobe
You're welcome.
I'm self-taught too. But being self-taught should include some education. That's why I suggested a book. You're trying to put a puzzle without the picture on the box. You need to understand how all the pieces fit together.
Ed
