Event Help
Event Help
Message 1 of 8
Event Help
I wanted to create an application event(Acad 2004), so that when a command is executed, the begining of command is used to set the corresponding layer. Can something like this be done? If yes, can someone get me some examples?
Replies (7)
Message 2 of 8
Put all of this code in the ThisDrawing module. Then, vbarun the StartAppEvents sub to instantiate Application level events. The rest should be self-explanatory.
Joe
Option Explicit
Dim WithEvents oApp As AcadApplication
Public Sub StartAppEvents()
Set oApp = Application
End Sub
Private Sub oApp_BeginCommand(ByVal CommandName As String)
MsgBox "The " & CommandName & " command just started"
End Sub
Private Sub oApp_EndCommand(ByVal CommandName As String)
MsgBox "The " & CommandName & " command just ended"
End Sub
Message 3 of 8
Thank you Joe, now is it possible to have the StartAppEvents()sub loaded everytime a drawing is opened or a new one is started?
Message 4 of 8
I use a line in my acad.lsp to run mine.
eg. (command "_-vbarun" "ApplicationEvents.InitializeEvents")
Regards - Nathan
Message 5 of 8
Or if you want to stick with vba, create a dvb
called acad.dvb. Then add this to a module.
Public Sub AcadStartup ()
    StartAppEvents
End Sub
Ed
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
Regards -
Nathan
Message 6 of 8
Thanks Ed, I keep forgetting about that. Regards - Nathan
Message 7 of 8
Ed, I already have a project that is loaded with every drawing. Now, my problem is that when I try copy the code on a module in the project I'm asked for the object, since the thisdrawing object is not used. Can you give me an example of how this works from another project?
Message 8 of 8
Ed, forget about the previous messag. I have a class object with the "Public WithEvents App As AcadApplication" then on a module I have the code + I added the AcadStartup()with the StartAppEvents, but nothing happens. Does the AcadStartup work only from an acad.dvb project? If I copy the code that joe gave on the thisdrawing code, it works fine. I already have a project that contains a lot of macros and I want to keep all macros in one single project. Is it possible to have this run from another project?
