STORING objects of a particular LAYER in SELECTION SET
Hi, i am stuck with this point.
Kindly guide,
Mniaz
here's a quick untested idea
emphasis on untested, but may give you the general
idea
Sub SelectLayerObjs(ByVal sLayName As
String)
    Dim LaySelSet As
AcadSelectionSet
    On Error Resume
Next
    Set LaySelSet =
ThisDrawing.SelectionSets.Item(sLayName)
      If
Err Then
Err.Clear
Set LaySelSet =
ThisDrawing.SelectionSets.Add(sLayName)
Else
LaySelSet.Clear
LaySelSet.Delete
'define type of
selection set (crossing, window, etc, in this case, all)
Dim mode As Integer
    mode = acSelectionSetAll
'this is a
selection set filter
    Dim gpCode(0) As
Integer
    Dim dataValue(0) As Variant
gpCode(0) = 8
    dataValue(0) =
sLayName
    Dim groupCode As Variant,
dataCode As Variant
    groupCode =
gpCode
    dataCode = dataValue
    'this
collects all objects on 'sLayName' layer into the seletion
set
    LaySelSet.Select mode, , , groupCode,
dataCode
    Dim NumOfLay As Integer
NumOfLay = LaySelSet.Count
    If NumOfLay = 1
Then
      MsgBox "There is only one lonely little
object on " & sLayName & " layer."
Else
      MsgBox "There are " & NumOfLay &
" objects on " & sLayName & " layer."
    End
If
  'clean up
LaySelSet.Clear
    LaySelSet.Delete
End
Sub
Kindly guide,
Mniaz
It worked very well.
Mniaz
