Error message when inserting blocks thru VBA routine
Message 1 of 8
Using AutoCAD 2018 when inserting blocks thru a VBA routine I am getting the following error message at random times and it causes AutoCAD to shut down.
Internal Error: !dbinsert.cpp@1349: eLockViolation
Can you help?
Felipe
Replies (7)
Message 2 of 8
norman.yuan
There were a few discussions on this topic:
https://forums.autodesk.com/t5/visual-basic-customization/internal-error-dbinsert-cpp-1309elockviola...
https://forums.autodesk.com/t5/visual-basic-customization/acad-2015-vba-elockviolation-error/m-p/504...
However, if those discussions do not help, you may want to post your all relevant code and describe in detail how the code is executed that results this error (maybe, also the drawing and the block used to run your code).
Also, have you tried to simplify the code (so that only very necessary lines that leads to the error are included) and then try with different drawing, different block to reproduce it?
Norman Yuan
Drive CAD With Code
Message 3 of 8
I would post the code but the problem is that I don't get the error every time.  I can execute the same section of code several times without a problem and then, for some reason, I get the error message and it shuts down.  Therefore, I don;t think that the code is the problem.  Would you agree?
Message 4 of 8
use the following code to insert block
dim filePath as String
dim insertionPoint as double
dim scale as integer
filePath = "the path of the block"
 Set objBlockRef = ThisDrawing.ModelSpace.InsertBlock(insertionPoint, filePath, scale(0), scale(1), scale(2), 0)
Message 5 of 8
I appreciate your reply but sometimes the code works fine and sometimes it
crashes when executing the same line of code. To me this means that there
is not a problem with the code because, if there was, it wouldn't execute at
all. Do you agree with me on this?
Message 6 of 8
Yes, I agree with you.
Even i was facing the similar problem but i solved the problem by saving the drawing file before executing the insert block code.
I used
ThisDrawing.Save
before the insert block code
Sometimes the inserting a block will give an error if the drawing file is not saved.
Please try it out
Please Checkout this page as well
https://forums.autodesk.com/t5/net/elockviolation-error-code-creating-a-new-layer-and-make-it-work/t...
Message 7 of 8
I'll give it a try sometime. And thanks for letting me know that my logic
about the code being correct at least made sense.
Message 8 of 8
Got the same issue here from AutoCAD 2019 onwards and only a few people with me have this error where on my side it does not occur.
Even trying to catch the error with the error trapping off does not work. I narrowed it down to the InsertBlock command and simplified the code, didn't work for me, same error.
i'm using the line in my VBA to import survey points from the Clipboard and then insert them in the drawing.
Unfortunately I cannot use the Drawing.Save method as the insertion might be invalid, save would overwrite the original drawing state. Could open the drawing, save it under a new, temp name, import the points and if OK, store the drawing back under its original name.....
One work round method does work: using the InsertBlock in a brand new. clean drawing works all the time fine without the error occurring, once I've used the import, the next time AutoCAD crashes at the next import run.
So: import the 1st time in a drawing goes well, open a new, clean drawing, import the points there, select them all, Clipboard => Copy, back to the 1st drawing, Clipboard => Paste to original coordinates and sorted.
I agree with the author here that it is not a programming error.
Hope someone at AutoDESK might have a direct solution to avoid the crash.
