How can I refer to AutoCAD block from Excel VBA
Hi all. I having autocad project where is 1 dynamic block which I'm trying to change from excel. Here is vba script which I'm using to change block:
Dim dybprop As Variant, i As Integer
Dim bobj As AcadEntity
For Each bobj In ACADApp.ModelSpace
    If bobj.ObjectName = "AcDbBlockReference" Then
        If bobj.IsDynamicBlock Then
            If bobj.EffectiveName = "AdjBlock" Then
                dybprop = bobj.GetDynamicBlockProperties
                For i = LBound(dybprop) To UBound(dybprop)
                    If dybprop(i).PropertyName = "Distance1" Then
                        dybprop(i).Value = 50.75
                        Acad.Application.Update
                Next i
Next
When I'm running it in AutoCAD VBA it works excellent. Than I'm creating Excel VBA project and copying this code. Before running it I creating connection to existing AutoCad project like this:
On Error Resume Next
   Dim ACADApp As AcadApplication
   Dim a As Object
   Set a = GetObject(, "AutoCAD.Application")
   If a Is Nothing Then
      Set a = CreateObject("AutoCAD.Application")
         MsgBox "AutoCAD must be running before performing this action.", vbCritical
         Exit Sub
   Set ACADApp = a
   Set ACADApp.ActiveDocument = ACADApp.Documents.Open("c:\KIRILL\Programming\Drawing1_VBATest.dwg")
When I'm running it from Excel VBA - AutoCAD project appears but nothing change. Honestly I don't have any idea why in Excel VBA it doesn't works while in AutoCAD it work. May be somebody had this problem before? Thanks in advance.
P.S. Full Excel VBA code:
Sub Button9_Click()
   Dim a As Object
         Exit Sub
   Set ACADApp = a
                Next i
Next
End Sub
Ed__Jobe
Possibly?
Should be:
For Each bobj In ACADApp.ActiveDocument.ModelSpace
Ed
How to post your code.
Yes... Oh thanks a lot. I spent a lot to solve this problem yet it was just inattentiveness Robot Sad
Ed__Jobe
Just noticed that Acad.Application should be AcadApp. You haven't declared a var called Acad.
Ed
