embedded macros
embedded macros
Message 1 of 9
embedded macros
hi
i was wondering if it was possible to extract an embedded macro via vba
thanks in advance
cheers
mark
Replies (8)
Message 2 of 9
As far as i know,its not possible. But if you save the macro in to module or
else you can import it .
"Mark Dubbelaar" wrote in message
news:3344C0BEEE568493D30B8EC584AB2431@in.WebX.maYIadrTaRb...
> hi
> thanks in advance
> cheers
> mark
Message 3 of 9
Ed__Jobe
Mark, It depends if you want to do it programmatically or not. If not, you can export/import modules as suggested before. Otherwise you can use the Application.VBE object to gain access to the vlide. Access a project via the VBProjects collection or the Application.ActiveProject property. Read/write code to the project's CodeModule.
Ed
How to post your code.
Message 4 of 9
ed,
what i am trying to do, is automatically extract an
embedded macro (if it exists)... when i first start using VBA i had a template
with an embedded project in it (i thought this was the only to achieve what i
was after) but later i found that you could use the acad.dvb to load vba
files... and hence i have a whole lot of drawings with this file embedded, which
is no longer needed.... if there is a way to programmatically extract the
embedded routine that would be good, otherwise i'll have to bit the bullet and
manually extract it....
cheers
 mark
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Mark,
Message 5 of 9
Ed__Jobe
I havn't tried to do what you ask, but I've seen other code segments that read/write to code modules, so it should be possible. Use the object browser to get familiar with the objects I mentioned earlier.
Ed
Message 6 of 9
Ed__Jobe
After looking into it further, you won't be able to use the VBE object since the vbaide doesn't have the ability to extract/embed vba. The vbaman dialog is the only thing in acad that will do it and unfortunately it will not run as a command line version, so you can't script it either.
Ed
Message 7 of 9
thanks for your help ed... i thought that might be
the case
After
Message 8 of 9
Unless I am misunderstanding this thread and/or your problem, simply
use:
Sub RemoveProj ()
Dim objProj as VBProject
Dim objIDE As VBE
Set objIDE = Application.VBE
'Iterate thru the VBE looking for
'any currently loaded projects
For Each objProj in objIDE.VBProjects
If objProj.Name = "MY_APP" Then
objIDE.VBProjects.Remove objProj
End If
Next
End Sub
Mike Tuersley
PhD @ CADalyst's AutoCAD Clinic
http://www.cadonline.com
Message 9 of 9
You might be able to use CodeModule.DeleteLines to wipe out all the code.
This should work if macro is in ThisDrawing module. If it's in another
module, you should be able to delete the module.
"Mike Tuersley" wrote in message
news:MPG.17fd10c9ac695e80989688@discussion.autodesk.com...
> use:
> Sub RemoveProj ()
> Dim objIDE As VBE
> End If
> Next
> End Sub
> Mike Tuersley
