Element not found
Element not found
Message 1 of 1
Element not found
A2Ki:
I am having problems with an ActiveX control created with VB. I can add the
control to the toolbox, but when I try to put the control on a form, all I
get is a Microsoft Visual Basic dialog that say "Element not found." The
previous version of the control worked as it should.
I tested the control in Access 2000, which has the same VBA version
(6/8714), and found that it works as it should.
Is there any known issues about VB ActiveX? Does anyone have a clue what is
causing my problem?
Rune Wold
System Analyst
Engineering Systems
rune@engsys.no
Replies (0)
