How to Pre-Select items in a Multi-select listbox????
I have code that "Should" upon loading the form check to see if toolbars are
loaded:
'cycle through the toolbars and add the appropriate menus to the lisbox
For Each objToolBar In objMenuGroup.Toolbars
strToolbarID = objToolBar.TagString
strCompare = Mid(strToolbarID, 1, IDLength)
If strCompare = strID Then
strToolbarName = objToolBar.Name
ListBox1.AddItem (strToolbarName)
Set objToolBar = objMenuGroup.Toolbars(strToolbarName)
If objToolBar.Visible = True Then
ListBox1.Selected(strToolbarName) = True
Else
MsgBox "something is wrong"
Next
Except no actual item in the multi - select listbox gets selected. How do i
select something through code.
> selected. How do i select something through code.
You need the index number of a list item, not the actual
text string, in order to select it. One way is to cycle
through the list looking for a match:
For i = 0 To Lisbox1.ListCount - 1
If strToolbarID = Listbox1.List(i) Then
Listbox1.Selected(i) = True
Exit For
Next
http://www.acadx.com
Try:
ListBox1.Selected(ListBox1.ListCount-1) = True
The Selected property expects an integer index value corresponding to the
item's position in the list. Since you're adding the items to the listbox,
the 'current' item would be the last item added.
Patrick Porter wrote in message
news:649CCD51C742DBE6B057D050802126AC@in.WebX.maYIadrTaRb...
are
> loaded:
> End If
> Else
> End If
> Next
i
