Edit dwg Properties
Edit dwg Properties
Message 1 of 26
Edit dwg Properties
Is it possible to edit the properties of a dwg file that isn't open in AutoCAD via VB/VBA/VL? I want to add summary information to the comments text box without opening the files.
Replies (25)
Message 2 of 26
ObjectDBX ?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5482448@discussion.autodesk.com...
Message 3 of 26
Agreed,
Is this code correct?
Option Explicit
' request reference to your current version of
' AutoCAD/ObjectDBX Common XX.0 Type Library
Sub AddSumInfoDBX()
On Error GoTo Err_Control
Dim fn As String
Dim oDBX As AxDbDocument
fn = "C:\temp.dwg"
Set oDBX = New AxDbDocument
Dim sInfo As Object
Set oDBX = Application.GetInterfaceObject("ObjectDBX.AxDbDocument.16") '<--17 for higher then A2005
' Add custom info
Set sInfo = oDBX.SummaryInfo
sInfo.Title = "Title"
sInfo.Author = "Me"
sInfo.Comments = "No comments, sir"
sInfo.Keywords = "Keywords"
sInfo.RevisionNumber = Format(Now, "dd/mm/yyyy")
sInfo.LastSavedBy = "Me"
sInfo.Subject = "Subject"
' Add custom properties (and remove prior one)
Dim cusKeys As Variant
Dim cusPropArr As Variant
Dim cusValArr As Variant
Dim i As Integer
Dim keyName1, keyName2, keyName3, keyName4
cusKeys = Array(keyName1, keyName2, keyName3, keyName4)
cusPropArr = Array("First Property", "Second Property", "Third Property", "Fourth Property")
cusValArr = Array("First Property Value", "Second Property Value", "Third Property Value", "Fourth Property Value")
For i = 0 To UBound(cusKeys)
sInfo.AddCustomInfo cusPropArr(i), cusValArr(i)
Next
oDBX.SaveAs fn
Set oDBX = Nothing
Err_Control:
MsgBox "Error Number: " & Err.Number & vbNewLine & _
"Error: " & vbNewLine & Err.Description
End Sub
~'J'~
Message 4 of 26
works great, thanks
Message 5 of 26
Glad if that helps
Cheers 🙂
~'J'~
Message 6 of 26
Ok this works to put in the author info, but drawing is set to a new drawing. I need it to edit an existing drawing, Any ideas? Thanks for the help.
Option Explicit
Sub AddSumInfoDBX()
Dim fn As String
fn = "C:\temp.dwg"
Dim sInfo As Object
Set oDBX = Application.GetInterfaceObject("ObjectDBX.AxDbDocument.17")
sInfo.Author = "Me"
oDBX.SaveAs fn
Set oDBX = Nothing
End Sub
Message 7 of 26
wrote in message news:5484240@discussion.autodesk.com...
help.
Option Explicit
Sub AddSumInfoDBX()
Dim fn As String
fn = FilenameToOpen '<----------
Dim sInfo As Object
'trap for errors of course...
oDbx.Open fn '<----------
sInfo.Author = "Me"
oDBX.SaveAs fn
Set oDBX = Nothing
End Sub
hth
Mark
Message 8 of 26
meck
Hi everyone,
I've been programming Inventor for 8 years now so programming AutoCAD is rather new to me. We are implementing Vault Pro and we have a huge amount of legacy drawing in AutoCAD that need to go into the vault. So I am trying to set the properties of these drawings using VB6. I have used the code provided here in this thread, but I am getting an error that says "Problem in loading application" on this line...
Set oDBX = oAcadApp.GetInterfaceObject("ObjectDBX.AxDbDocument.17")
I have referenced the AutoCAD Type Library 2013 and the AutoCAD/ObjectDBX Common 19.0 Type Library (which for some reason I have 2 in my reference list and I've tried both).
Any help here would be greatly appreciated!
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
Message 9 of 26
meck
I tried changing the ObjectDBX.AxDbDocument.17 to ObjectDBX.AxDbDocument.19 and now I get a Type Mismatch error.
BTW will I be able to edit the property values?
This is my code...
Dim oAcadApp As AcadApplication          'The AutoCAD application object
Set oAcadApp = GetObject(, "AutoCAD.Application")
Set oDBX = oAcadApp.GetInterfaceObject("ObjectDBX.AxDbDocument.19")
Mike Eck
Using Inventor 2018
Message 10 of 26
meck
No help?
Anyone?
Mike Eck
Using Inventor 2018
Message 11 of 26
Can this be done with Microsoft access?
Message 12 of 26
Ed__Jobe
Yes, but acad needs to be installed on the pc in order for the class to be registered, and your project needs to reference AutoCAD/ObjectDBX Common ##.# Type Library.
Ed
How to post your code.
Message 13 of 26
Done...  Can you suggest code?
Message 14 of 26
Ed__Jobe
^^ Look above.
Ed
Message 15 of 26
AcadApplication does not work with the 22.0 library.
Message 16 of 26
Ed__Jobe
Look at Marks' reply in post 7. You don't need to use AcadApplication. You use the odbx app instead.
Ed
Message 17 of 26
Working on it now.  Thanks for your help!
Message 18 of 26
Ugh...  GetInterfaceObject doesn't work either...
Message 19 of 26
Ed__Jobe
Did you substitute 22 for 19? Is 22 the version you have installed? What version of acad are you running? You can check the registry in the Classes section.
Ed
Message 20 of 26
The object library is 22.0.  We are running Civil 3d 2018.
