Draw line between two ends of lines
12:49 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am getting Run-time error 5 "invalid procedure call or argument" when i try to draw a line from Point to End_line, see below:
Dim Dline As AcadLine Dim Point(0 To 1), End_line(0 To 1) As Variant Set Dline = ThisDrawing.ModelSpace.AddLine(Point, End_line)
here is the full code
Option Explicit Sub Find_Lines() Dim ent As AcadEntity Dim SP, EP, Point(0 To 1), End_line(0 To 1) As Variant Dim Dline As AcadLine Dim min_x, min_y, min_Dist, dist As Double Dim min_name As String Point(0) = 0 Point(1) = 0 min_Dist = 100001 For Each ent In ThisDrawing.ModelSpace If TypeOf ent Is AcadLine Then If ent.Layer = "Travel_Path" Then SP = ent.StartPoint EP = ent.EndPoint Call Find_Min_Point(Point, SP, EP, dist, End_line) If dist < min_Dist Then min_name = ent.Handle min_Dist = dist min_x = End_line(0) min_y = End_line(1) End If 'i = i + 1 End If End If Next ent Debug.Print min_name, min_Dist, min_x, min_y End_line(0) = min_x End_line(1) = min_y Set Dline = ThisDrawing.ModelSpace.AddLine(Point, End_line) End Sub Sub Find_Min_Point(Point As Variant, SP As Variant, EP As Variant, dist As Double, End_line As Variant) Dim m, b, step, x, y, x_plus, y_plus, this_dist, next_dist As Double step = 0.01 this_dist = 100001 next_dist = 100000 m = Get_Slope(SP, EP) b = Get_Intercept(SP, m) 'Debug.Print "StartPoint: ", SP(0), SP(1), "EndPoint: "; EP(0), EP(1), "m: ", m, "b: ", b If SP(0) < EP(0) Then x = SP(0) Else x = EP(0) End If Do x_plus = x + step y = m * x + b y_plus = m * x_plus + b this_dist = GetDistance(Point(0), x, Point(1), y) next_dist = GetDistance(Point(0), x_plus, Point(1), y_plus) x = x_plus Loop Until next_dist > this_dist 'Debug.Print x, y, this_dist dist = this_dist End_line(0) = x End_line(1) = y End Sub Function Get_Slope(SP As Variant, EP As Variant) As Double If (EP(0) - SP(0)) = 0 Then Get_Slope = 0 Else Get_Slope = (EP(1) - SP(1)) / (EP(0) - SP(0)) End If End Function Function Get_Intercept(SP As Variant, m As Variant) As Double Get_Intercept = SP(1) + m * SP(0) End Function Function GetDistance(x1 As Variant, x2 As Variant, y1 As Variant, y2 As Variant) As Double GetDistance = Sqr((x1 - x2) ^ 2 + (y1 - y2) ^ 2) End Function Sub Ch4_AddLightWeightPolyline() Dim plineObj As AcadLWPolyline Dim points(0 To 5) As Double ' Define the 2D polyline points points(0) = 2: points(1) = 4 points(2) = 4: points(3) = 2 points(4) = 6: points(5) = 4 ' Create a light weight Polyline object in model space Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points) ThisDrawing.Application.ZoomAll End Sub
