AutoCAD 2014 VBA
AutoCAD 2014 VBA
AutoCAD 2014 VBA
Problem: looking for the shortest line between a point and a collection of other lines
Is there a VBA solution for such a problem? I could start concentric circles form the point until they intersect with a line but I am wondering if a solution already exists, thanks.
Alfred.NESWADBA
I would go through all lines, calculate the shortest vector
  • your point to a point vertical to your line
  • in case the calculated vertical is not on the line (between line's start- and endpoint), then the closer endpoint
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
you may want to give more info/examples about your goal and starting data
