Doubts on XData
Doubts on XData
Doubts on XData
Hi All,
I want to store the Application Name as XData to an Object. Is it necessary to add both XDataType 1001 and 1000, but i want to add only Application name. The first item in XData is 1001 why not 1000.Thanks in Advance.....
With regards,
Basha
Hi Basha!
You have to store XDataType 1001 with corresponding XData (Your Application
Name)
Under XDataType 1000 you can store a string in the corresponding XData.
(see DXF Group codes in DXF-HELP for more Codes over 1000)
If you only store XDataType 1001 with corresponding XData (Your Application
Name)
all Information of only YOUR Application are removed.
Your Bernie
wrote in message news:5434607@discussion.autodesk.com...
Hi All,
Advance.....
With regards,
Basha
Hi All,
Appending XData to Objects in a drawing does increase the size of a drawing?
Thanks & Regards,
Basha
