not code error in vba, vba not read exce data
it's believale thing happen
ever if vba code has not error, basic program did not read excel file
vba not read excel file and to run and to terminate
what is problem? who is know reason?
code following
data attached is vba code,and excel file
following is code
Dim xlapp As Excel.Application
Dim xlbook As Excel.Application
Dim xlsheet As Excel.worksheet
Dim xlrange As Excel.Range
Dim pointobj As AcadPoint
Dim location(0 To 2) As Long
Dim ra, dec As Double
Dim radegree As Double
Dim decdegree As Double
Dim dist As Double
Dim indx As Double
Dim jndx As Double
Dim lngrows As Double
Dim lngcols As Long
Dim mas As Long
Dim sign As String
Dim coeff As Integer
Dim cof As Integer
Dim radtrad As Long
Dim decdtrad As Long
MsgBox "be patience,works slowly"
On Error Resume Next
Err.Clear
Set xlapp = GetObject(, "excel.application")
Set xlapp = CreateObject("excel application")
Const pi = 3.141592
xlapp.Display.alerts = False
xlapp.Visible = True
xlapp.WindowState = xlMinimized
Set xlbook = xlapp.Workbooks.Open(FileName:="c:\200mas.xls")
xlsheet.Activate
'get excel data
lngrows = xlbook.activesheet.usedrange.Rows.Count
lngcols = xlbook.activesheet.usedrange.Columns.Count
AcadApplication.widowstate = acMax
Set xlsheet = xlbook.worksheet(1)
ReDim dataarr(lngrows - 1, lngcols - 1)
For indx = 1 To lngcols
For jndx = 11 To lngrows
dataarr(indx - 1, jndx) = xlsheet.Cells(indx, jndx):
dataarr(indx - 1, jndx + 1) = xlsheet.Cells(indx, jndx + 1):
dataarr(indx - 1, jndx + 2) = xlsheet.Cells(indx, jndx + 2):
ra = dataarr(indx, jndx)
dec = dataarr(indx, jndx + 1)
mas = dataarr(indx, jndx + 2)
If xlsheet.Cells(indx, jndx) = "ra" Then
indx = indx + 1
sign = Left("dec", 1)
If sign = "-" Then
coeff = -1
Else
coeff = 1
sign = Left(dec, 1)
If sign = "+" Then
cof = 1
radegree = 15 * Val(Mid("ra", 1, 2)) + 15 * Val(Mid("ra", 4, 2)) / 60 + 15 *
Val(Mid("ra", 7, 6)) / 3600
decdegree = Val(Mid("dec", 2, 2)) * coeff * cof + Val(Mid("dec", 5, 2)) * coeff * cof /
60 + Val(Mid("dec", 8, 6)) * coeff * cof / 3600
'in hipparcos,distance display mas(mili-arcs-econd), so must do 1000/mas
dist = (1000 / Val(mas)) * 3.26 'dist is parsec 5*3.26 light year
radtrad = (radegree / 180) * pi 'ra transferring from degree to radian
decdtrad = (decdegree / 180) * pi 'dec tranfering from degree to radian
'cosmic 3-D point (x,y,z)- sine cosine is used
'modelspace command is dist
location(0) = dist * Cos(decdtrad) * Cos(radtrad): location(1) = dist * Sin(radtrad) *
Cos(decdtrad): location(2) = dist * Sin(decdtrad)
Set pointobj = ThisDrawing.ModelSpace.AddPoint(location)
Next
Next
ZoomAll
xlapp.DisplayAlerts = True
xlbook.Close savechanges:=False
xlapp.Quit
Set xlsheet = Nothing
Set xlbook = Nothing
Set xlapp = Nothing
DoEvents
Why not use the editing tools in the VBA editor to step through your code
and see where the error is occurring yourself?
Simply open the file with your code, put the cursor in the Sub routine and
press F8 to step through one line of code each time you press F8
Laurie Comerford
CADApps
www.cadapps.com.au
www.civil3Dtools.com
wrote in message news:5434632@discussion.autodesk.com...
code following
following is code
Dim dec
degree As Double
Dim dist As Double
Dim indx As Double
Dim jndx As Double
Dim lngcols As Long
Dim mas As Long
Dim sign As String
Dim cof As Integer
Dim radtrad As Long
Err.Clear
Const pi = 3.141592
xlsheet.Activate
'get excel data
1):
2):
mas = dataar
r(indx, jndx + 2)
indx = indx + 1
If sign = "-" Then
coeff = -1
Else
coeff = 1
sign = Left(dec, 1)
If sign = "+" Then
cof = 1
coeff * cof /
Sin(radtrad) *
Next
Next
ZoomAll
xlap
p.Quit
Set xlapp = Nothing
DoEvents
I do not unnerstanding error about looping for-next sentence
see and see do not undenstand
it is difficulty problem
it's 3d map of galaxy's arm' (pointing method)
attachted file is vba code file and excel data file
thanks to your advice about f8 ,it is so useful
Until you build your own skills up to the stage where you are capable of
identifying where your errors are occurring and searching the newsgroups for
answers which have been posted to similar problems and interpreting the
answers so as to apply to your problem, you should not be trying to code
such a complex project.
Why don't you write a simpler program and get it to work first so as to
build your skills?
Also, you should read the help file each time you get an error, so as you
can understand why you are getting the error.
Laurie Comerford
CADApps
www.cadapps.com.au
wrote in message news:5434707@discussion.autodesk.com...
