Distinguish the two identical documents in the different Autocad instances
How can I distinguish the two identical documents that are open in different instances of the Autocad application? I can't find properties in the Autodesk.AutoCAD.Interop.AcadDocument class that can distinguish these documents.
I have a task to determine other open instances of the document, except for the active one (the documents are open in other Autocad application instances also can be Active).
Thank you!
Ed__Jobe
The com interop api doesn't have file system properties. Use the vb FileSystem to compare file attributes.
Ed
How to post your code.
