Searching All Specific Text in TextObject and assign to a Layer CAD VBA
I have around 5000 textObject in CAD 2013. I create 200 Layers through VBA code. I know a lot about Excel VBA but i'm new in CAD VBA. My problem is, searching specific text in CAD Model and assign to named layer. Something Like
Dim i as Integer
Dim strToFind as String
strToFind =Column1
For i=1 to textObject.Count 'textObject.Count total number of textObject in CAD
  If textObject(i)=strToFind Then 'textObject are text object to search in CAD
  textObject(i).Layer=ColumnLayer 'ColumnLayer is named layer in CAD
  Endif
Next
norman.yuan
In AutoCAD, there are 2 types of entities (AcadText and AcadMText) that would the "TextObject" you are referring to, if we do not count attributes in a block reference.
To find all the text-objects (AcadText and/or AcadMText), you can either use AcadSelectionSet with filter to select them, or you can simply loop through Model/PaperSpace to find them. For xample, assuming you are interested in all text-objects in ModelSpace, you can do this:
Dim ent As AcadEntity
Dim txt As AcadText
Dim mtxt As AcadMText
Dim textValue As String
For Each ent in ThisDrawing.ModelSpace
     textValue=""
    If TypeOf ent Is AcadText Then
        Set txt=ent
        textValue=txt.TextString
    Else If TypeOf ent Is AcadMText Then
        Set mtxt=ent
        textValue=mtext.TextString
    End if
    If textValue<>"" Then
        Select Case UCase(textValue)
             Case "XXXX"
                 ent.Layer="Layer1" ''' You may want to make sure the layer does exist before you can assign it to an entity
             Case "YYYY"
                  ent.Layer="Layer2"
        End Select
Next
Norman Yuan
Drive CAD With Code
