CUI Unload
CUI Unload
CUI Unload
I am having problems completely unloading a partial CUI at the end of an AutoCAD session. This CUI is loaded with only specific drawings so it needs to be unloaded when these drawings are closed. I have unloaded it through the AutoCAD ActiveX extensions but it must not be completely unloaded because it reappears the next time I start AutoCAD.
Is there something more that I can do with VBA to fix this problem? Thanks for any help that you can give!
If you do not perform a save on the parent cui file, the changes made via
ActiveX are only for the current session.
R. Robert Bell
wrote in message news:5053003@discussion.autodesk.com...
What VBA function do I use to save a CUI file? I can't seem to find any documentation on this!
John Bisschop
The MenuGroup object has that method.
R. Robert Bell
wrote in message news:5054005@discussion.autodesk.com...
John Bisschop
The AutoCAD 2006 ActiveX/VBA Reference states the Save method is no longer supported for menu groups. But, there is no indication of a replacement function.
I am so far unable to find another solution.
