I want my dvb to unload itself
Is there any way to have a dvb unload itself? I've looked at vba
extensibility but haven't found what I want.
Any suggestions would be appreciated.
Thanks in advance,
Mike Weaver
Hi Mike,
It may not be entirely what you want, but it is very easy to use one DVB to
load another, run it and then unload it.
I've been doing this with some of our utility programs as for my purposes
it's easier to do that than detect changes in the AutoCAD environment and
end up with the user getting information from the wrong drawing.
Alternatively:
If you run your DVB macros with Lisp, then the lisp could unload the program
as well as load it.
Laurie Comerford
CADApps
www.cadapps.com.au
"Mike Weaver" wrote in message
news:5053087@discussion.autodesk.com...
Thanks in advance,
Mike Weaver
fxcastil
http://discussion.autodesk.com/thread.jspa?messageID=433008
I ended up leaning toward the lisp approach. I wish it could be done
entirely from the DVB, but this will work well enough.
Thanks for the resonse,
Mike Weaver
"Laurie Comerford" wrote in message
news:5053126@discussion.autodesk.com...
Hi Mike,
Alternatively:
as well as load it.
Laurie Comerford
CADApps
www.cadapps.com.au
Thanks in advance,
Mike Weaver
I've always used SendCommand - probably not ideal, but it works.
ThisDrawing.SendCommand "_vbaunload" & vbCr & """Your File.dvb""" & vbCr
Matt W
"I did absolutely nothing, and it was everything I thought it could be."
news:5054821@discussion.autodesk.com...
Mike Weaver
Hi Mike,
Alternatively:
as well as load it.
Laurie Comerford
CADApps
www.cadapps.com.au
Thanks in advance,
Mike Weaver
