Search Excel for a Value
Message 1 of 10
I have a ton of this sort of worked out but I need to figure out how to solve this!
I want my app to have a user select a piece of text in autocad and it scane the first column in an excel file and when it finds the value of the textstring a msgbox says what the value in column 2 is...can anybody help me?
With oSheet
If LTrim(.Cells(2, 1)) = oSpaceNo.Value Then 'Row then column)
MsgBox (.Cells(2, 2))
If LTrim(.Cells(3, 1)) = oSpaceNo.Value Then 'Row then column)
MsgBox (.Cells(3, 2))
If LTrim(.Cells(4, 1)) = oSpaceNo.Value Then 'Row then column)
MsgBox (.Cells(4, 2))
If LTrim(.Cells(5, 1)) = oSpaceNo.Value Then 'Row then column)
MsgBox (.Cells(5, 2))
End With
Replies (9)
Message 2 of 10
Sub stub1()
Dim oRange As Range
For Each oRange In ActiveSheet.UsedRange
If oRange.Value = "test" And _
oRange.Column = 1 Then
MsgBox oRange.Offset(0, 1).Value
Next oRange
End Sub
gl - Paul
wrote in message news:5053143@discussion.autodesk.com...
solve this!
me?
With oSheet
End With
Message 3 of 10
fxcastil
A simple for/next loop will work
dim indx as integer
with OSheet
for Indx= 1 to 10
If LTrim(.Cells(indx, 1)) = oSpaceNo.Value Then
'Row then column)
MsgBox (.Cells(indx, 2))
end if
next
end with
Fred Castillo
Message 4 of 10
Both of these options still keep reading everything in each row...would a case statement work better? Like this
With oSheet
Select Case Value
Case oSpaceNo.Value = LTrim(.Cells(2, 1))
Case oSpaceNo.Value = LTrim(.Cells(3, 1))
End Select
End With Message was edited by: stck2mlon
Message 5 of 10
fxcastil
Add an "exit for" to exit the loop when value is found this
will stop searching when value is found
for Indx= 1 to 10
'Row then column)
exit for ' the value was found exit the loop
end if
next
Fred Castillo
Message 6 of 10
I am not sure how to fix this...it just returns the same value regardless of the index. Also, will the index mean I have to know how many rows are in my worksheet, because I have 106 workbooks with 2 worksheets in each one 😞
Private Sub cmdSelect_Click()
Me.Hide
'--------Get The Space Number--------
'Declare Variables
Dim returnobj As Object
Dim entbasepnt As Variant
'For Handle Storage
Dim entHandle As String
Dim entry As AcadEntity
'For Handle Storage
On Error Resume Next
ThisDrawing.Utility.GetEntity returnobj, entbasepnt, "Select Text: "
'For Handle Storage
For Each entry In returnobj
entHandle = returnobj.ObjectID
Next
'--------Start the Excel Query--------
Dim oExcel As Excel.Application
Dim oWBK As WorkBook
Dim oSheet As WorkSheet
Dim oSpaceNo
Dim indx As Integer
oSpaceNo = Trim(returnobj.TextString)
UserForm1.Hide
Err.Clear
Set oExcel = GetObject(, "Excel.Application")
oExcel.visible = False
Set oWBK = Workbooks.Open(FileName:="C:\Data\Consulting\WHC\test.xls")
Set oSheet = oExcel.Worksheets(1)
With oSheet
For indx = 1 To 10
'Row then column)
Exit For ' the value was found exit the loop
Next
End With
WorkBook.Close True, "C:\Data\Consulting\WHC\test.xls"
'Me.Show
End Sub
Message 7 of 10
Have you considered using the find method?
Either that or use the worksheet function vlookup.
With oSheet
End With
Message 8 of 10
fxcastil
You can use the "usedrange" property of Excel
to get the row count
IntRows=oSheet.Usedrange.Rows.count
see this link for other methods and samples.
http://discussion.autodesk.com/thread.jspa?messageID=5043090
I am not sure what you mean by
" it just returns the same value regardless of the index"
but the routine look fine to me.
Test the routine like below and see what happens
With oSheet
For indx = 1 To IntRows
Msgbox LTrim(.Cells(indx, 1))
Next
Fred Castillo
Message 9 of 10
I am not sure how the find method applies here. The user has selected a piece if text...open excel and find the value in a specific row and return all of the values for that recordset.
Message 10 of 10
These kinds of conversations work better if you don't wait 4 days to reply.
Ranges have find methods. The find method can return the first cell that
matches your search criteria. If you want the address,then access the
address property of the cell returned. If you want the row, then access
the row property of the cell. Use the offset methods to get adjacent cells
if you want. It seems like you are trying to write code to essentially
replace what is done automatically for you via the find method.
Perhaps I'm wrong.
wrote in message news:5057216@discussion.autodesk.com...
