Creating Rectangle When Intersections Occur
Ray-Sync
Ray-Sync
I have this:
I will show you a VBA code in AutoCAD that creates a new rectangle when it detects an intersection between two polylines. The dimensions of this new rectangle are based on the maximum dimensions of the previous rectangles. The problem is that the code only works if the first polyline intersects with the others, but I want it to continue checking with the second and subsequent polylines without including the previous one, since that has already been done. Then it should proceed with the third polyline and the remaining ones, excluding the previous ones, because that has also been completed, and so on. I would greatly appreciate any kind of assistance. Thank you."
Private Sub CommandButton1_Click()
    Dim Sset As AcadSelectionSet
    Dim filterType(0) As Integer, i As Integer, j As Integer
    Dim filterData(0) As Variant
    Dim PL() As AcadLWPolyline, pol As AcadLWPolyline
    Dim p(0 To 5) As Double, p1(0 To 5) As Double, p2(0 To 9) As Double
    Dim D(2) As Double
    Dim l As AcadLine
    Dim pt(0 To 2) As Double, pt1(0 To 2) As Double
    'seleccionar polilíneas de la capa "column"
    filterType(0) = 8: filterData(0) = "COLUMN"
    Set Sset = ThisDrawing.SelectionSets.Add("2K")
    Sset.Select acSelectionSetAll, , , filterType, filterData
    ReDim PL(Sset.Count - 1)
    'asignar variable pl para manipularlas
    For i = 0 To Sset.Count - 1
        Set PL(i) = Sset.Item(i)
    Next i
    'Empezar iteración de todas las polilíneas con respecto a la polínea inicial
    For i = 1 To Sset.Count - 1
        'verificar si los rectangulos se intersectan
        If UBound(PL(0).IntersectWith(PL(i), acExtendNone)) <> -1 Then
        'Conseguir las coordenadas del segundo rectangulo
            For j = 0 To 5
             p(j) = PL(1).Coordinates(j)
            Next j
            'Conseguir las dimensión más larga del segundo rectangulo
           D(0) = Abs(p(0) - p(2)): D(1) = Abs(p(3) - p(5))
            If D(0) > D(1) Then
               D(2) = D(0)
            Else
               D(2) = D(1)
            End If
        'Conseguir las coordenadas del primer rectangulo
            For j = 0 To 5
             p(j) = PL(0).Coordinates(j)
            Next j
          'Conseguir las dimensión más larga del primer rectangulo
          'condicional para crear nuevo rectangulo
            If D(0) > D(1) Then
            'asignar coordenadas para nuevo rectangulo
               For j = 0 To 3
               p2(j) = p(j)
               Next j
               pt(0) = p2(0): pt(1) = p2(1)
               pt1(0) = p2(2): pt1(1) = p2(3)
               Set l = ThisDrawing.ModelSpace.AddLine(pt, pt1)
               p2(4) = p2(2) - D(2) * Sin(l.Angle): p2(5) = p2(3) + D(2) * Cos(l.Angle)
               p2(6) = p2(0) - D(2) * Sin(l.Angle): p2(7) = p2(1) + D(2) * Cos(l.Angle)
               p2(8) = p2(0): p2(9) = p2(1)
               Set pol = ThisDrawing.ModelSpace.AddLightWeightPolyline(p2)
            Else
           'Esto sucedería si no se cumple la primera condición
               For j = 2 To 5
               p2(j) = p(j)
               Next j
               pt(0) = p2(2): pt(1) = p2(3)
               pt1(0) = p2(4): pt1(1) = p2(5)
               p2(6) = p2(4) - D(2) * Sin(l.Angle): p2(7) = p2(5) + D(2) * Cos(l.Angle)
               p2(8) = p2(2) - D(2) * Sin(l.Angle): p2(9) = p2(3) + D(2) * Cos(l.Angle)
               p2(0) = p2(8): p2(1) = p2(9)
            End If
                 l.Delete
        End If
    Next i
    Sset.Delete
    ThisDrawing.Regen acActiveViewport
End Sub
jefferson
Ray-Sync
I have the solution but I think it can be improved
    Dim filterType(0) As Integer, i As Integer, j As Integer, h As Integer
    Dim D(2) As Double
    Dim l As AcadLine
    Set Sset = ThisDrawing.SelectionSets.Add("1")
    Next i
        For j = i + 1 To Sset.Count - 1
            If UBound(PL(i).IntersectWith(PL(j), acExtendNone)) <> -1 Then
                For h = 0 To 5
                    p(h) = PL(j).Coordinates(h)
                Next h
                If D(0) > D(1) Then
                    D(2) = D(0)
                Else
                    D(2) = D(1)
                End If
                For h = 0 To 5
                    p(h) = PL(i).Coordinates(h)
                Next h
                If D(0) > D(1) Then
                    For h = 0 To 3
                        p2(h) = p(h)
                    Next h
                Else
                    For h = 2 To 5
                        p2(h) = p(h)
                    Next h
                End If
                l.Delete
            End If
        Next j
    Next i
    Sset.Delete
End Sub
jefferson
