Create a view in several layout by user
ossareh.hamidreza
ossareh.hamidreza
Dear All,
I hope all is well with you. I try to write a VBA code in AutoCAD to :
1- Create a requested number of layouts from user by user form and create them
2- Delete all current objects from each created layout
3- The user selects its first view and put it in layout 1, then selects the second view and put it in layout 2, .......
Please review the current code: When you run, it works up to step two above correctly and does well in step three but only for one layout, and it does not continue its job up to the end one. I will be highly appreciated it if someone helps me.
Codes:
Public explicity
Dim objAcadObject As AcadObject
Dim NumberofLayouts As Integer, NumberofRequired As Integer
Private Sub DoCreatelayout()
Dim currentLayout As AcadLayout
Dim LayoutName As String
'Dim NumberofLayouts As Integer, NumberofRequired As Integer
Dim Count As Integer
Dim entry As AcadEntity
ThisDrawing.ActiveSpace = acPaperSpace
NumberofRequired = UserForm1.TextBox1.Text
For Each currentLayout In ThisDrawing.Layouts
LayoutName = currentLayout.Name
If LayoutName <> "Model" Then currentLayout.Delete
Next
ThisDrawing.ActiveLayout = ThisDrawing.Layouts("Layout1")
For Each objAcadObject In ThisDrawing.PaperSpace
If TypeName(objAcadObject) = "IAcadPViewport" Then objAcadObject.Delete
Next
For Count = 2 To NumberofRequired
ThisDrawing.Layouts.Add ("Layout" & Count)
ThisDrawing.ActiveLayout = ThisDrawing.Layouts("Layout" & Count)
Next
Next
ThisDrawing.Regen acActiveViewport
End Sub
Private Sub CommandButton1_Click()
DoCreatelayout
UserForm1.Hide
ThisDrawing.SendCommand "mview" & vbCr & "NEW" & vbCr
Next
End Sub
Ed__Jobe
Welcome to the VBA forum. When posting code, put your code into the code window by clicking on the </> button. It should look like this:
Sub MySub()
End Sub
The problem lies in using the SendCommand method. It is not synchronous, i.e. is runs after the VBA code is finished. Therefore its not in a loop and only runs once. Use the VBA API to add entities instead of AutoCAD commands. Use ThisDrawing.Viewports.Add() and then set the viewport properties.
Dim oVP As AcadViewport
Set oVP = ThisDrawing.Viewports.Add
With oVP
  'set properties
  .LowerLeftCorner = point1
  .UpperRightCorner = point2
  .Layer = "Viewports" 'make sure layer exists first
End With
Ed
How to post your code.
ossareh.hamidreza
Dear Sir\Madam,
So many thanks for your kind advice. In your submitted code, for the viewport property, I would like to let the user to select his views by using window action. are there any specific commands to ask the user to do that?
Thanks in advance.
For example in:
Set PViewportObject = PaperSpaceCollection.AddPViewport(CenterPoint, _
Width, Height)
Instead of CenterPoint, width, and height parameters, how is it possible that the user selects the viewport by a window in model space.
Regards
Ed__Jobe
@ossareh.hamidreza wrote:
Dear Sir\Madam,
It's Sir Ed. 🙂
Have a look at the Utility object's methods. You can use GetPoint twice. Search this forum for sample code.
Note that I've been linking to the ActiveX Developer Reference. It's acadauto.chm on your hd.
Ed
