Compline error in hidden module : ModcadFunction
Gaganpatel
Message 1 of 25
Gaganpatel
Dear Sir,
Please see the attached error massage used autocad 2020 64bit & help me.
Option Explicit
Dim BNSize(1 To 100) As String
Dim BNQty(1 To 100) As Integer
Dim SS As AcadSelectionSet
'Count BN from layers BN1,BN2,BN4
Sub BNCount()
Dim BoltSize As String
Dim BoltQty As Integer
Dim LayerQty As Integer
Dim Boltstr As Variant 'as Variant because split function return array
SelectBN
If SS.Count = 0 Then
MsgBox "No Valid Bolt Nut Block selected"
Exit Sub
End If
Call FillArray(BNSize, "") 'LIB sub
Call FillArray(BNQty, 0) 'LIB sub
Dim BNBLOCK As Variant
Dim BNAtt As Variant
Dim Count As Integer
Dim Donut As AcadLWPolyline
Dim VarDIMSCALE
Dim Errfound As Boolean
VarDIMSCALE = ThisDrawing.GetVariable("DIMSCALE")
Errfound = False
If findlayer("TEMP") = False Then
ThisDrawing.Layers.Add "TEMP"
End If
For Each BNBLOCK In SS
LayerQty = Val(Right(BNBLOCK.Layer, 1))
If BNBLOCK.HasAttributes Then
BNAtt = BNBLOCK.GetAttributes
For Count = LBound(BNAtt) To UBound(BNAtt)
If InStr(BNAtt(Count).TextString, "-") > 0 Then ' if - found in att then
Boltstr = Split(BNAtt(Count).TextString, "-")
BoltQty = Val(Boltstr(0))
If BoltQty = 0 Then ' if qty = 0 or any non numeric string then
Set Donut = AddDonut(ThisDrawing.ModelSpace, VarDIMSCALE * 5#, VarDIMSCALE * 10#, BNBLOCK.InsertionPoint)
Donut.Color = acMagenta
Donut.Layer = "TEMP"
Errfound = True
Else
BoltSize = Boltstr(1)
AddTOBNSum BoltSize, BoltQty * LayerQty
End If
Else
Errfound = True
End If
Next Count
End If
Next BNBLOCK
If Errfound Then
MsgBox "Error found , Atrribute without - or Qty not valid number "
Else
Call WriteBNSum
End If
SS.Clear
Set SS = Nothing
End Sub
Private Sub SelectBN()
Dim FType
Dim FData
BuildFilter FType, FData, 2, "B1,B2,B3,B4,B5,B6,B7,B8,B9,B10", 8, "BN1,BN2,BN3,BN4"
On Error Resume Next
Set SS = ThisDrawing.SelectionSets("SS")
If Err Then Set SS = ThisDrawing.SelectionSets.Add("SS")
SS.Clear
SS.SelectOnScreen FType, FData
End Sub
Private Sub AddTOBNSum(BoltSize, BoltQty)
Dim I As Integer
For I = 1 To 100
If BNSize(I) = BoltSize Then
BNQty(I) = BNQty(I) + BoltQty
Exit Sub
End If
Next
For I = 1 To 100
If BNSize(I) = "" Then
BNQty(I) = BoltQty
Exit Sub
End If
Next
End Sub
Private Sub WriteBNSum()
Dim pnt As Variant
Dim ExtraPer As Double
Dim AddNo As Integer
Dim Textheight As Integer
Dim Vspacing As Integer
Dim Hspacing As Integer
Dim VarDIMSCALE
pnt = ThisDrawing.Utility.GetPoint(, vbCr & "Select Insertion point : ")
ExtraPer = GetRel("Extra % of Bolt Nut", 0, 4) 'LIB Function (4 not allow -Ve)
AddNo = GetInt("Additional No of Bolt nut", 0, 4) 'LIB Function
Textheight = VarDIMSCALE * GetInt("Text Height", 3, 6) 'LIB Function
Vspacing = Textheight + VarDIMSCALE * GetInt("Vertical spacing", 3, 6) 'LIB Function (6 not allow 0 & -Ve)
Hspacing = VarDIMSCALE * GetInt("Horigontal spacing", 40, 6) 'LIB Function
If findlayer("TEXT") = False Then
MsgBox "Text layer not found , Creating text layer"
ThisDrawing.Layers.Add "TEXT"
End If
Call WriteStringArray(BNSize, pnt, Textheight, Vspacing, "TEXT") 'LIB SUB
'Inc BN qty based on extra % or add no
Dim BNper As Integer
Dim BNadd As Integer
Dim I As Integer
For I = 1 To 100
If BNQty(I) = 0 Then Exit For
BNper = Int(round((BNQty(I) * (100# + ExtraPer) / 100#), 0))
BNadd = BNQty(I) + AddNo
If BNper > BNadd Then
BNQty(I) = BNper
Else
BNQty(I) = BNadd
End If
Next
Dim X As Double
Dim Y As Double
Dim Z As Double
X = pnt(0) + Hspacing
Y = pnt(1)
Z = pnt(2)
pnt = point3d(X, Y, Z) 'LIB FUNCTION
Call WriteNumberArray(BNQty, pnt, Textheight, Vspacing, "TEXT") 'LIB SUB
End Sub
*Moderator edit* Please post code to a code window.
Replies (24)
Message 2 of 25
Gaganpatel
Dear Sir,
Any body please help me.
Message 3 of 25
Ed__Jobe
Instead of trying to run the code, open it in the VBA IDE. Click on Debug>Compile and the compiler will break on the line that has the problem.
Ed
How to post your code.
Message 4 of 25
Gaganpatel
Dear Sir,
I have trying but problem not solved.
Please help me solve my problem.
Code is available on previous post.
Message 5 of 25
Ed__Jobe
I know you've been trying, but did you try Debug>Compile?
Also, you didn't post all your code. There are functions called that are missing. If you want us to find the "hidden module", you need to post your whole dvb. Zip it first.
Ed
Message 6 of 25
Gaganpatel
Dear Sir,
Please find the attached DVB file & Please help .
Message 7 of 25
Ed__Jobe
They are all missing references. Are you missing any references on your pc.
Ed
Message 8 of 25
Gaganpatel
Dear Sir,
Please solve my problem.
Message 9 of 25
Ed__Jobe
I can't if you don't answer my questions. See posts 5 and 7. If you don't understand English well enough, then use Microsoft Translator.
Ed
Message 10 of 25
Gaganpatel
Dear Sir,
All reference file are active.
Please see the attached image.
Message 11 of 25
Ed__Jobe
Getting information out of you sure isn't easy. Can you be more thorough? You didn't answer the question in post 5? Did you try to compile? Also, you never posted Nitin Cad Library.dvb.
Ed
Message 12 of 25
Gaganpatel
Dear Sir,
Please find the attached Nitin_CAD.dvb
Message 13 of 25
Ed__Jobe
First tell me if you tried compiling?
Ed
Message 14 of 25
Gaganpatel
Dear Sir,
Yes i have tried .
I don't VBA programming.
I request you please help me.
Message 15 of 25
Ed__Jobe
The dvb you uploaded is password protected. You need to remove the password protection and upload it again.
Ed
Message 16 of 25
Gaganpatel
Dear Sir,
Please find the attached password removed .dvb file.
Message 17 of 25
Ed__Jobe
Please post a zip, not rar.
Ed
Message 18 of 25
Gaganpatel
Dear Sir,
Please find the attached .dvb file
Message 19 of 25
Ed__Jobe
Replace your BoltCount.dvb with this one. I removed the reference to Nitin_CAD_Library and imported the modules into it. That dvb was corrupted and was not updated for 64 bit. You will have to add the reference to DAO again. I do not have that tlb. I don't use DAO anymore.
Ed
Message 20 of 25
Gaganpatel
Dear Sir,
Many Many Thanks , Working good
15 Nos. file are same problem how to solve problem. Please help me.
