Combo Box Clear problem
Hi all,
I have a form with three combo boxes. On this form I have a "clear" button
that allows the user to "clear" the values of the combo boxes when it is
clicked. Here is what is going on: I have one combo box (cboA) that
populates two others (cboB and cboC). cboA contains items 1-9. When an
item is selected, cboB and cboC are enabled and populated based on what was
selected in cboA. Basically cboB is populated with very convoluted layer
names and cboC is populated with the definition of those layers (this way
the user can pick by layer name or layer description). So when a layer in
cboB is selected, the corresponding layer description is highlighted in
cboC. When the clear button is pressed, the current value of all three
combo boxes are supposed to "clear", but cboC will not clear properly. If
cboC is selected first rather than cboB, and the clear button is clicked,
all three clear with no problems. Below is the code for the clear button.
It almost seems like the enabled property of cboC is firing before the clear
property when cboB has been selected first. Does anyone have any insight as
to why this may be happening?
Private Sub cmdClear_Click()
cboFeatureType.Clear '(cboA)
cboSDSLayName.Clear '(cboB)
cboObjType.Clear '(cboC)
cboSDSLayName.Enabled = False
cboObjType.Enabled = False
Call UserForm_Initialize
End Sub
TIA,
Rob
Have you tried stepping through it in the debugger to see if it's stepping
into one of your cbo events when it's cleared?
Glen
"Rob Outman" wrote in message
news:1724D5D465311A54297B213C2FFB7B3C@in.WebX.maYIadrTaRb...
> Hi all,
button
was
clear
as
> End Sub
> TIA,
> Rob
Rob, I suspect you have an event cascade causing the problem. Start by
putting break points in the routines that populate your combo boxes, I'm
betting you'll see one of your routines fire after the clear method is
executed.
> Hi all,
button
was
clear
as
> End Sub
> TIA,
> Rob
Hi guys,
I did what was suggested and it somehow magically worked itself out!
Thanx for the input!
Rob
"Jacob Dinardi" wrote in message
news:EC2C4687CBED8CAE1CE35C819EEBB04E@in.WebX.maYIadrTaRb...
> executed.
> > Hi all,
> button
> was
layer
way
in
If
clicked,
button.
> clear
insight
> as
> > End Sub
> > TIA,
> > Rob
