Unloading Delphi dll
Set obj = New MyProj.MyClass ' calls initialize
Set obj = Nothing ' calls destructor
How can I call the destructor from within the dll without causing an Access
Violation (free does this)
ie when the user closes the form AutoCAD unloads dll (the vba Set
obj=Nothing destroys the form prematurely)
Can you describe in more detail how your project is
structured?
"Joe Parker" wrote in message
news:97CCFD0A463E866E2E8549D6848257CB@in.WebX.maYIadrTaRb...
Access
my automation object basically calls a form as follows. The form does a load
of stuff independant of AutoCAD and has an Ok button that closes the form
when the user is finished. I want the destructor to be called at this stage
but I get Access Violation if I try to free anywhere in this unit.
Question 2: Why does (ExtractFileName(Application.EXEName)='ACAD.EXE') (only
on some systems) return false when called from inside my Delphi dll writtrn
for AutoCAD
unit AcForm_IMPL;
interface
uses
ComObj, ActiveX, Windows, AcForm_TLB, StdVcl, Main_Form,AutoCAD_TLB;
type
TTest = class(TAutoObject, ITest)
private
FForm1: TForm1;
Acad:AcadApplication;
protected
function Get_Visible: WordBool; safecall;
procedure Set_Visible(Value: WordBool); safecall;
procedure GetApplication(const _Acad: IDispatch); safecall;
{ Protected declarations }
public
Procedure Initialize; override;
Destructor Destroy; override;
end;
implementation
uses ComServ;
procedure TTest.Initialize;
begin
Inherited Initialize;
FForm1 := TForm1.Create(nil);
end;
destructor TTest.Destroy;
begin
FForm1.Free;
inherited destroy;
end;
function TTest.Get_Visible: WordBool;
begin
Result := FForm1.Visible;
end;
procedure TTest.Set_Visible(Value: WordBool);
begin
FForm1.Visible := Value;
end;
procedure TTest.GetApplication(const _Acad: IDispatch);
begin
Acad:=_Acad as AcadApplication;
FForm1.Acad:=Acad;
end;
initialization
TAutoObjectFactory.Create(ComServer, TTest, Class_Test,
ciMultiInstance, tmApartment);
end.
"Tony Tanzillo" wrote in message
news:3454CD0B9515F6E88B4610C82B78BAC0@in.WebX.maYIadrTaRb...
> structured?
> Access
news:19E2A941B6B7FAE93A1BA1E4D916AF94@in.WebX.maYIadrTaRb...
load
stage...
Revise your ActiveX server to eliminate the Visible
property and just expose a single method called Show():
Procedure TTest.Show
var
Form1: TForm1;
begin
try
Form1.ShowModal;
finally
Form1.Free;
end;
end;
Using the above method, the form is created, shown, and
destroyed each time you use it from the client.
(only
writtrn
> for AutoCAD
If this is an ActiveX DLL than you shouldn't be using
Application.ExeName. What is it you're trying to get
(the name of the ActiveX .dll, something else)?
thanks for the reply tony
1. I was hoping not to ShowModal as I want the user to be able to interact
with Acad. I only want the Automation Object destroyed if the Ok button is
selected
2.My main form can be a stand alone application where
ExtractFileName(Application.EXEName) returns the name of my application (in
my case HollowCore)
or it is called by an Automation Object (built in a dll called by AutoCAD)
where
(ExtractFileName(Application.EXEName) returns 'ACAD.EXE' (on most systems)
depending on the result of the function I dress up the form in different
ways
I suppose what I want to do is know is whether the form is operating from
inside a dll or is it the main form of a standalone application
news:02AB8423FE6463F9A0BDA1BBBFF6C307@in.WebX.maYIadrTaRb...
> load
form
> stage...
> var
> Form1: TForm1;
> begin
> try
> Form1.ShowModal;
> finally
> Form1.Free;
> end;
> end;
> (only
> writtrn
> > for AutoCAD
See below for some comments on using modeless
Delphi forms in AutoCAD.
> user to be able to interact with Acad. I only
> button is selected
You cannot destroy your ActiveX object, as long as
there is one or more references to it in the VBA
client. This is what's causing the AV. You have
to keep in mind that a COM object's lifetime is
controlled by its clients. As long as one or more
clients holds a reference to your COM object, you
cannot destroy it.
To get around this, you can do the following:
In your form, declare a public property of type
IUnknown, and a private variable of the same
type:
type
TForm1 = class(TForm)
private
FCOMObject: IUnknown;
public
Property ComObject: IUnknown read FCOMObject write FCOMObject;
end;
In your COM object's Initialize() method:
begin
// Let the form keep a reference to this COM object
FForm1.ComObject := Self As IUnknown;
end;
Then, add an OnClose handler to your form, and
in it, set the CloseAction to caHide, and release
the COM object:
TForm1.OnClose((Sender: TObject; var Action: TCloseAction);
begin
CloseAction := caHide;
FComObject := Nil;
end;
Just call IsLibrary() and if it returns True, then
you are running in a .DLL.
Some comments on using modeless Delphi forms in AutoCAD:
Without some extensive programming, using a Delphi Form
modelessly in AutoCAD will not work entirely as expected.
The reason for this is because much of the functionality
that Delphi forms and controls implement are dependent
on the Delphi Application object (TApplication) having a
message pump, which is not the case when your form runs
in a non-Delphi host.
For example, when your form is shown modelessly in the
ActiveX dll, you will note that you can't use the TAB
key to advance focus from one control to the next. A
number of other things will not work correctly also.
I have a solution for this, but I will need to package
it up in a form that you can use. I developed a special
Delphi form class called TAcadForm, which is derived
from Delphi's TForm, and is "AutoCAD aware". IOW, it
will function properly as a modeless form when used in
AutoCAD's process.
I will need some time to put in a package along with
any other required units, and once I do, I'll post it
on my web page.
Excellent, thx
news:B5B2E11D0AA6F623A2E7A0891EFD73C7@in.WebX.maYIadrTaRb...
> > button is selected
> cannot destroy it.
> type:
> type
> private
> public
> end;
> begin
> end;
> the COM object:
> begin
> FComObject := Nil;
> end;
from
> AutoCAD's process.
> on my web page.
