Colour palette not showing colours
If on a form I select the ForeColor property of a control and select the
Palette tab nothing shows. If I pick a point then the color is set but I
don't really want to keep guessing until I get the correct colour. I just
tried it in a macro in Word and that's OK. Any ideas?
Dave Preston
Technical Dev. Engineer
C A Design Services Limited
Address: Design Centre, Hewett Rd, Gapton Hall,
GREAT YARMOUTH,
Norfolk 31 0NN,
Tel: 01493 440444,
Fax: 01493 442480,
E-Mail: dpreston@cadesignservices.co.uk,
Web Site: www.cadesignservices.co.uk,
Registered in England No. 1595687
This e-mail and any attached files is confidential and intended for the
addressee(s) only. It may contain privileged and confidential information,
and may not be disclosed to anyone else. Unauthorised recipients are
requested to preserve this confidentiality by deleting the original and to
advise the sender immediately of any mistakes in transmission. Internet
communications are not secure and therefore C A Design Services Limited does
not accept any legal responsibility for the contents of this message, and
the message and files are opened at the risk of the recipient. Unless
otherwise specifically stated any views or opinions are solely those of the
author and do not represent those of C A De
Realy weird...
Did you try re-installing AutoCAD?
If it does not help, mabee reinstalling Office could (mabee and possibly) fix it....
If not, no clue at all..... Good luck!
Been that way as long as I can remember. Still has not changed
in 07. Keep using the editor, other things will bug you more and
you'll soon forget..:)
"Dave Preston" wrote in message
news:5229892@discussion.autodesk.com...
Dave Preston
GREAT YARMOUTH,
Norfolk 31 0NN,
Tel: 01493 440444,
Fax: 01493 442480,
arcticad
I have the same problem. I've installed in on a dozen computers and it always is missing the palatte.
(defun botsbuildbots() (botsbuildbots))
Many thanks, I'll try it on some of the others at work
Regards
Dave Preston
wrote in message news:5230486@discussion.autodesk.com...
