Tooltip problem still
OK, I have a form and I have tool tips on most controls.
If I set the form's showModal property to True the tool tips display, but if
I set it to False they do not.
I have Referenced the AutoCAD Focus Control but this makes no difference.
Does anyone have a solution please?
Dave Preston
Technical Dev. Engineer
C A Design Services Limited
Address: Design Centre, Hewett Rd, Gapton Hall,
GREAT YARMOUTH,
Norfolk 31 0NN,
Tel: 01493 440444,
Fax: 01493 442480,
E-Mail: dpreston@cadesignservices.co.uk,
Web Site: www.cadesignservices.co.uk,
Registered in England No. 1595687
This e-mail and any attached files is confidential and intended for the
addressee(s) only. It may contain privileged and confidential information,
and may not be disclosed to anyone else. Unauthorised recipients are
requested to preserve this confidentiality by deleting the original and to
advise the sender immediately of any mistakes in transmission. Internet
communications are not secure and therefore C A Design Services Limited does
not accept any legal responsibility for the contents of this message, and
the message and files are opened at the risk of the recipient. Unless
otherwise specifically stated any views or opinions are solely those of the
author and do not represent those of C A De
Worked for me ... are you using VB or VBA?
"Dave Preston" wrote in message
news:5229922@discussion.autodesk.com...
Dave Preston
GREAT YARMOUTH,
Norfolk 31 0NN,
Tel: 01493 440444,
Fax: 01493 442480,
VBA
Dave Preston
GREAT YARMOUTH,
Norfolk 31 0NN,
Tel: 01493 440444,
Fax: 01493 442480,
"Joe Sutphin" wrote in message
news:5230123@discussion.autodesk.com...
Dave Preston
GREAT YARMOUTH,
Norfolk 31 0NN,
Tel: 01493 440444,
Fax: 01493 442480,
I'm using AutoCAD 2006 if that makes a difference. The tool tips only work
if you click on them, not when you hover over them.
Even if the form is not set to modal The AutoCAD main window has focus and
not the form so I guess it needs focus?
Dave Preston
GREAT YARMOUTH,
Norfolk 31 0NN,
Tel: 01493 440444,
Fax: 01493 442480,
news:5230162@discussion.autodesk.com...
VBA
Dave Preston
GREAT YARMOUTH,
Norfolk 31 0NN,
Tel: 01493 440444,
Fax: 01493 442480,
Dave Preston
GREAT YARMOUTH,
Norfolk 31 0NN,
Tel: 01493 440444,
Fax: 01493 442480,
Can you post a copy of the DVB in question? I'm curious to see if it'll act the same way here.
Matt W
[Insert funny quote/saying here]
I am running 2006 as well. I create a userform [with the focus control on
it] and a startup routine in the ThisDrawing module like this
Public Sub Test()
UserForm1.Show vbModeless
End Sub
Then at the command prompt I type vbarun and select the Test sub to run.
As is typically of all Windows apps, you will not get tooltips of apps [in
this case your UserForm] that do not have focus.
Joe ...
news:5230163@discussion.autodesk.com...
Dave Preston
GREAT YARMOUTH,
Norfolk 31 0NN,
Tel: 01493 440444,
Fax: 01493 442480,
VBA
Dave Preston
GREAT YARMOUTH,
Norfolk 31 0NN,
Tel: 01493 440444,
Fax: 01493 442480,
Dave Preston
GREAT YARMOUTH,
Norfolk 31 0NN,
Tel: 01493 440444,
Fax: 01493 442480,
Well I guess I did something really dim. I included the reference to the
acFocus control but didn't actually add it to my form
I hadn't realised as I had no textboxes on it - Doh! Thanks to everyone for
the help
Regards
Dave Preston
news:5230524@discussion.autodesk.com...
Public Sub Test()
End Sub
Joe ...
Dave Preston
GREAT YARMOUTH,
Norfolk 31 0NN,
Tel: 01493 440444,
Fax: 01493 442480,
VBA
Dave Preston
GREAT YARMOUTH,
Norfolk 31 0NN,
Tel: 01493 440444,
Fax: 01493 442480,
Dave Preston
GREAT YARMOUTH,
Norfolk 31 0NN,
Tel: 01493 440444,
Fax: 01493 442480,
