Code can not run in Toolbar
hieut1392
hieut1392
I am creating a macro that displays the name of a block by selecting an object. When I run the code in the VBA Editor, there is no problem (image 1). But when I add my macro to a custom toolbar, the code understands that the object is not selected, when I click on the icon on the toolbar and the code flies straight to line 13. (image 2). Can anyone help me?
Option Explicit
Sub GetBlockName()
    Dim blkRef As AcadBlockReference
    Dim obj As Object
    Dim pt(0 To 2) As Double
    Dim blockName As String
    On Error Resume Next
    ThisDrawing.Utility.GetEntity obj, pt, "Pick a block"
    If Err <> 0 Then
        MsgBox "No block", vbExclamation, "Error"
        Exit Sub
    End If
    If TypeOf obj Is AcadBlockReference Then
        Set blkRef = obj
        blockName = blkRef.Name
        MsgBox "Block name: " & blockName, vbInformation, "Name Block"
    Else
        MsgBox "Not Block!", vbExclamation, "Error"
    End If
End Sub
Ed__Jobe
What is your toolbar macro?
Ed
How to post your code.
