Changing Dynamic Block Visibility with a macro
Message 1 of 24
I'd like to modify the code below (posted by Allen Johnson on Dynamic Blocks Forum) so that instead of modifying the visibility of "cirtagleader" block, I could modify the visibility of all the blocks in my drawing that the name start with SYM-M.
Can any one help?
Private Sub ScanBlks()
Dim dybprop As Variant, i As Integer
Dim bobj As AcadEntity
For Each bobj In ThisDrawing.ModelSpace
If bobj.ObjectName = "AcDbBlockReference" Then
If bobj.IsDynamicBlock Then
If bobj.EffectiveName = "cirtagleader" Then
dybprop = bobj.GetDynamicBlockProperties
For i = LBound(dybprop) To UBound(dybprop)
If dybprop(i).PropertyName = "Visibility" Then
dybprop(i).Value = "Leader Off"
End If
Next i
End If
End If
End If
Next
End Sub
Thanks a lot,
Maxime Sanschagrin
Replies (23)
Message 2 of 24
wrote in message
news:[email protected]...
start with SYM-M.
Can any one help?
'>>>>>change here
'If bobj.EffectiveName = "cirtagleader" Then
If bobj.EffectiveName Like "SYM-M*" Then
End If
Next i
End If
End If
End If
Next
End Sub
hth
Mark
Message 3 of 24
Bingo!!!
Thanks a lot MP.
Maxime
Message 4 of 24
I would also strongly advise checking that there is a visibility state of "Leader Off"
before making the change or else the routine will error out.
Phil Custer, P.E.
Custer Services, Inc.
[email protected]
On Wed, 18 Oct 2006 09:08:21 +0000, MP wrote:
> wrote in message
>Hi,
>start with SYM-M.
>Can any one help?
>'>>>>>change here
>End If
>Next i
>End If
>End If
>End If
>Next
>End Sub
>hth
>Mark
Message 5 of 24
I don't have any knowledge of VB. What happens if the "routine will error out"? I tried it and it worked, but not all of my blocks have the visibility "Leader Off". I don't want to mess things up.
Maxime.
Message 6 of 24
What I was refering to was checking the ".AllowedValues" variant array to insure that your
visibility state is there. It is not good practice to depend on AutoCAD VBA not producing
an error in this version (they change the way things work with every version).
Base on your previous code it would look like.
[code]
Dim varAllowVis as Variant
Rem New Code Here
varAllowVis = dybprop(i).AllowedValues
For j = 0 to UBound(varAllowVis)
If varAllowVis(j) = "Leader Off" Then
Exit For
End If
Next j
Rem End of New Code
End If
Next i
End If
End If
End If
Next
End Sub
[/code]
Phil Custer, P.E.
[email protected]
>Thanks,
>Maxime.
Message 7 of 24
Thanks a lot Phil! Really nice of you to help someone like me who doesn't know nothing about VBA. I'll be taking VBA lessons soon and I hope I'll be able to help people instead of "begging" for help ;o)
Maxime
Message 8 of 24
Trust me I need the help just as much as anyone!
>Maxime
Message 9 of 24
Hey,
im curious as to what i have to change to get it to look in paper space instead of model?
ive tryed changing
to
For Each bobj In ThisDrawing.ActiveLayout
but i just get errors. any help would be great thanks.
Message 10 of 24
Hi, I'm trying to switch off/on the visibility of my block, but I'm trying to do this with a command Button. How do I make this?
I would  like to click in a Check box, activating and deactivating the visibility, of various dynamics blocks. For example 4 dynamic blocks. How can I do it?
Private Sub CommandButton1_Click()
Dim i As Integer
If bobj.EffectiveName = "Luminaria_Dinamica" Then
dybprop(i).Value = "leader off"
End If
Next i
End If
End If
End If
Next
Message 11 of 24
kasperwuyts
to
For Each bobj In ThisDrawing.ActiveLayout.block
Might seem unlogical at first, but the 'block' part of a layout contains all the geometry and is the equivalent of 'ModelSpace'. 'PaperSpace' would work too, but ActiveLayout.block is more universal.
Best regards
Kasper Wuyts
_______________________________________________________________________________
If this post solves your problem, clicking the 'accept as solution' button would be greatly appreciated.
Message 12 of 24
Hello everyone, I am trying to do something very similar to the original macro provided but for some reason it's not working for. I think this might be a simple solution but I just wanted to see if you guys have some input, as i am running out of ideas. Any and all help will be appreciated. Thanks!
Message 13 of 24
Ed__Jobe
You need to tell us more than "Its not working". What errors are you getting? I see you are in break mode. What line is failing to complete? Describe your problem in more detail.
Ed
How to post your code.
Message 14 of 24
Thank you for replying so quickly! When I try to run it I get the "Run time error '424': Object Required"; Messagebox gives me the option to end or debug, I click end and nothing happens or I click debug and  it highlights "For Each bobj In ThisDrawing.ModelSpace". I'm not sure what the problem is because I also have turned on the references to the AutoCAD libraries so I think it should be able to understand the autocad references.  I'm not sure what the issue is. I have another code I use (to insert blocks) where the libraries are not needed ( non-binding, i think it's called) and the autocad references are dimmed as objects and such and I'm not sure if maybe I should try to translate this code into that manner. But with this code i am trying to incorporate control over visibility.  Please let me know if
Message 15 of 24
Ed__Jobe
The code you show in your last post doesn't appear to have anything to do with your first post. However, it looks like you are running inside xl. The ThisDrawing object doesn't exist in xl. You need to dim it and then instantiate it via
Set ThisDrawing = AcadApplication.ActiveDocument
Also, when you show code, don't give us a picture of it. Paste the actual code into a code window using the </> symbol on the reply toolbar.
Ed
Message 16 of 24
Correct, the code in the last picture doesnt have anything to do with this one I just wanted to show you a reference of how I got blocks to be inserted in a different code. Also, you're right, I am doing this via Excel. Now I've dimmed ThisDrawing As AcadDocument and the code doesn't break when I run it anymore, but now nothing is happening, no the dynamic block on AutoCAD is not changing at all. Here's what I have :
Dim ThisDrawing As AcadDocument
If bobj.EffectiveName = "FSM4L-ENDCAPS" Then
dybprop(i).Value = "FSM4L-TF-ENDCAP"
End If
Next i
End If
End If
End If
Next
End Sub
Message 17 of 24
Ed__Jobe
Can you post a dwg with your block in it?
Ed
Message 18 of 24
Yes I can. Thank you!
Message 19 of 24
I sure can, Thank you!
Message 20 of 24
Ed__Jobe
I made the following changes in red.
Public Sub ScanBlks()
                        If dybprop(i).PropertyName = "Visibility1" Then
                            ThisDrawing.Regen acActiveViewport
                        End If
                    Next i
                End If
            End If
        End If
    Next
Ed
