can t delet selectionset
Hello
it drives me crazy ...
i want to check if selection set already exist , if yes then delete it. but it seems it works not every time. after the second time i can t create the selectionset. acad says its already exist.
here my code
Dim ssetObj As AcadSelectionSet
Dim ssetObj2 As AcadSelectionSet
Dim ObjSS As AcadSelectionSet
For Each ObjSS In ThisDrawing.SelectionSets
Debug.Print ObjSS.Name
If UCase("Regio_SSET") = UCase(ObjSS.Name) Or UCase("Subt_SSET") = UCase(ObjSS.Name) Then
ThisDrawing.SelectionSets.Item(anzi).Delete
End If
anzi = anzi + 1
Next
Set ssetObj = ThisDrawing.SelectionSets.Add("Regio_SSET")
take a look at my respond here
http://discussion.autodesk.com/thread.jspa?threadID=103847
huii, that should go in acad help
thank you!
Tom
Hi TOM!
NEVER delete an entity of the loop while being in a FOR EACH!
You have to set a marker inside the loop and then (after then Next-Statment)
delete the marked entity!
(And if you use "OPTION COMPARE TEXT" before your sub you need not use UCASE
ssMarker = false
for each sset in Thisdrawing.Selectionsets
if sset.name = "regio_sset" then ssMarker = true
next
if ssMarker then Thisdrawing.Selectionsets("regio_sset").Delete
wrote in message news:5434663@discussion.autodesk.com...
Hello
here my code
End If
anzi = anzi + 1
Next
I do not agree
Why to not use Exit For instead of marker?
Somethink like this:
ssName = "regio_sset"
if sset.name = ssName then
sset.Delete
Exit For
next
~'J'~
